as41 case
https://forums.aussieveedubbers.com/threads/5588/as41-case
kafer70 ·
How do you tell if you have an as41 case ?
and if it isn't is that such a bad thing.
It says so!
under the tubes on one side of the motor it is cast in.
It could/should be either a AS41 or maybe a AS 21
The as 41's are the "standard" mag case. Dual relief etc etc
The AS 21's are a bit rarer and have a higher aluminium content.
Then there are the new aluminium cases. Dont know anyone who has run them
yeah the new cases are heavier... n much rougher on the insides from being sand cast in lieu on die cast like the magnesium cases.
there suspost to be stronger ect etc time will tell
