FaT_BuG ·
accordin to my workshop manual my beetle is ment to come with reversin lights and it doesnt have em.eny ideas and i want to rewire the whole car....
https://forums.aussieveedubbers.com/threads/560/re-wiring-a-1970-beetle
FaT_BuG ·
aussiebug ·
FaT_BuG ·
bugmeister ·
Grey 57 ·
FaT_BuG ·
aussiebug ·
You must have a very old bug to have the wiring through the roof - I forget which year they changed, but most bugs have the wiring though from the engine bay into the left side panel next to (under) the rear seat and then it tracks forward near the floor in a channel set into the heater channel under the left door - it then turns upwards just in front of the door (behind the left side carpet) and through a grommet into the front luggage area.bugmeister wrote:Ok 2 Q's maybe someone maybe able to help out on.
What's the best way to get the wiring through the roof under the rain gutter (as per the factory). I was thinking tying a rope to the end to the old wiring harness as I pulled it out (thus pulling the rope through) and then in turn tying that to the new and pulling it through. Just my pathetic thought on the problem, although I'm sure a there is a better/simpler method.
Secondly, what's the best way of threading wire through PVC tubing. Doing it pisses me off so much, I'm considering running the split corrugated PVC stuff and wrapping it with insulation tape.
Cheers.
70AutoStik ·
aussiebug ·
Phil74Camper ·
kombi_kid ·
aussiebug ·
Good point Phil, and quite possible since the 67 Aussie built car was still essentially a 62 model - the Clayton factory found it too expensive to do the full list of changes with each beetle model and concentrated on the cosmetic stuff.Phil74Camper wrote:My old Beetle, made June 1964, had the wiring harness run through the roof; perhaps all the Aussie-manufactured cars did it that way and they changed to a floor harness for the CKD cars from 1968?
