NEW WEDGEMATED FULL CIRCLE CRANK
https://forums.aussieveedubbers.com/threads/56003/new-wedgemated-full-circle-crank
RodPenrose ·
I have one only 82 mm , vw jnl {std}, type 1 main {010}, welded , fullcircle , wedgemated crankshaft and flywheel from Demmello Machine in USA priced @ $1100 . This unit was made for me and I have no use for it now . The crank is Demmello's race crank that is welded , magnafluxed , nitrited and balanced with 11/32 dowells , 12 LB flywheel and shim pack that sells for US$ 900 . My loss is your gain if you want to produce over 250 hp and not have any flywheel problems . ROD , 02-42729920 .
