Where to get portawalls installed
https://forums.aussieveedubbers.com/threads/56080/where-to-get-portawalls-installed
oval TOFU ·
Let's say hypothetically, a friend is going to get whitewalls for her bug. Where can I point her to get them installed properly? Preferably in the eastern 'burbs of Melberg, but she'll travel to get it done correctly.
I've heard of people installing the 'walls themselves, but as far as I know, isn't the tyre bead really difficult to break from the rim? ..and you will also need that sealant stuff too?
Chris
rupewrecht ·
Beaurepaires in Ringwood did mine. The boss there used to have a bug himself so seems to know what he's doing. Haven't had a problem with mine in the couple of months they've been installed.
oval TOFU ·
is he still working there? I've dealt with other B'repairs before and they don't really know much about old cars and associated elements... You've currently got protawalls one your bug right now don't ya?
rupewrecht ·
Yeah, hes still there - i drive past most days and usually see him in the workshop. And yep, i've got Omega portawalls on.
I think i was just lucky to find a beaurepaires that had VW knowledge - i got a leak, and needed a tyre (ended up buying 4 as the resst were shagged anyway) and got the portawalls a few weeks later and he installed them for next to nothing.
oval TOFU ·
does this man of merit have a name?
rupewrecht ·
Not that i can remember! Might have been Andrew...but don't quote me.
oval TOFU ·
"Andrew.." ok. *writes it down...*
oh wait... ok..
right.
oval TOFU ·
anyone else have any suggestions?
Volkswagenboy ·
Buy a tire fitting machine like I did!
-Staggers.
SPRINTSTAR ·
I've been doing it for ten years,really easy. Give me a call and I'll tell you how it's done at your local servo. Which one's are you using, Atlas or Peter's Tyre Trim etc...rubber or plastic based type whitewalls? Finally, are you running radials or cross ply and if it's a daily driver on radial's,be prepared to change your tyres every six months coz it eats the sidewall..:thumb
oval TOFU wrote:anyone else have any suggestions?
phatratpat ·
Volkswagenboy wrote:Buy a tire fitting machine like I did!
-Staggers. [/quote
you have a tyre fitting machine ?
_ falls over.
hows the hand? 🙄
Volkswagenboy ·
Yeah I have a pneumatic tyre machine, and the hand is getting better.
Who told you??
-Staggers.
phatratpat ·
🙅 YOU DID DUMB ASS ! at the show on sunday.........😂
Volkswagenboy ·
I did? Oh... That's right! Hmm too much blood in my alcohol system!
-Staggers.
oval TOFU ·
SPRINTSTAR wrote:I've been doing it for ten years,really easy. Give me a call and I'll tell you how it's done at your local servo. Which one's are you using, Atlas or Peter's Tyre Trim etc...rubber or plastic based type whitewalls? Finally, are you running radials or cross ply and if it's a daily driver on radial's,be prepared to change your tyres every six months coz it eats the sidewall..:thumb
Hey mate
I was thinking of getting the Atlas ones on radial Michies. However, I'm not sure I'll be going down that track after all as the Conti's on the front have a rim protector bar on the tyre and will mess with having the portawalls on em unless i can grind/cut the excess rubber from the tyre - not such an attractive prospect...
Robo ·
If your gunna use radials why dont you just buy some proper Coker whitewall radials? I run Nankang crossplys with Omega whitewall inserts. I put them on myself. Just let the tyre down broke the bead put em in and reinflated the tyre again, easy!
Rob....
oval TOFU ·
Robo wrote:If your gunna use radials why dont you just buy some proper Coker whitewall radials? I run Nankang crossplys with Omega whitewall inserts. I put them on myself. Just let the tyre down broke the bead put em in and reinflated the tyre again, easy!
Rob....
Coker whitewall radials - coz it's winter and my money tree is only starting to show buds...
Nankang crossplys - it's my daily driver and I want more security than crossplys.. Didn't know you Nankang still made cross plys though..
Robo ·
They are gettin hard to get now. Last set I bought 12 months ago.
Rob...
