Roller Pedal to Irs Pan
https://forums.aussieveedubbers.com/threads/56086/roller-pedal-to-irs-pan
Turbo54 ·
Hi All,
I want to use me roller pedal assembly for my turbo54 project and I was wondering if anyone on here has done the mods to get it to work on a later model pan? Any help / pics / advice / would be greatful,
T54
I've never really looked at the roller...
but I have seen them in late model beetles..
so, it must be possible...
it may just fit on the end of the shaft...
or You may need an early longer shaft??
someone in the USA may make them to fit later assemblies
??? if they are different...
66deluxe ·
I'm putting my 66 bug on a 70 semi auto pan and will be using the later pedals all i am going to do is cut off the little wheel and shaft under the flat accel pedal and weld a bolt to it and then will be using a skateboard wheel as my roller, i modified the early 66 pedal set and just put the skatebord wheel on that and held it on with a bolt and nut and it worked a treat.
