Hi, I took the motor out of my daughters car last week. Not as hard as I thought. My question is this. I have made up a sort of trolley from an old swivel chair so i can move it around the shed but I want to lift it up to work on it properly. Does anyone have a picture of an engine stand they have which I could duplicate. Otherwise I was thinking of using a block and tackle from the shed roof but dont want to damage the push rod tubes and cant find any suitable lift points. Any help much appreciated.
AL
bout $50 at supashit doesnt need anything flash as its not heavy
CHADMYSTER ·
do they sell em? Supa cheap i mean
CHADMYSTER ·
i see classic has a bench mount one. it should be cheaper
bond ·
depends what you have in mind for the donk - if you are just doing heads and seals and a general clean up then sit it atop a bench otherwise if you are going complete rebuild then might be an idea to invest in a stand on a trolly
nick
CHADMYSTER ·
hopefully just seals and clean up but you never know when you start.i have all the materials at home to make one. Where do the 2 arms on the stand locate on the motor. Do they bolt to to the main rear bolts etc?
CHADMYSTER ·
it leaks oil even when sitting. thought it was the main crank seal but it may be allright. It may be the join in the case itself. Want to give it a good claen to find out.
AL
Euro_67 ·
Ask Craig Torrens as he Knows every thing
You can never know everthing, just more than some.
Chadmyster, as 64_Notch was unable to help with your request for info I thought I would post a pic of what I use. Basically its a $55 supercheap item with a Kombi bellhousing bolted to it.:thumb
You can then also run a starter for engine testing etc.
Happy to help with advice:thumb
crewcabconnection ·
does that stand come with the motor Craig?
72super ·
thats a great idea Craig. hard part is finding spare bell housings?
crewcabconnection wrote:does that stand come with the motor Craig?
