I have a set of good gondition Solex 40 P11s splitshafts.
These are original carbs off Porsche 356 and 912s
They are also original issue off VW Ascorts - which is where i believe these came from.
These are Italian made
Shafts are firm.
Vents are 32.
I "think" the idles are 55 and airs are 195 - but buggered if i know where the mains live. I can find these on the top.
Havent really pulled them to pieces.
There is a piece broken on what i am guessing is the choke / enrichment?? - you can see it in the pictures. Dont think it matters as you disable it like in webers.
Parts are freely available at
http://www2.kochracingengines.com/search1.cfm
These "can" fit Weber 40 manifolds. I have sat them on a set - you just need to enlarge the bolt holes a poofteenth and clear part of the webbing between the inlets for the pump shafts IF the manfolds are the solid web type.
Normal linkage and filters for Webers will fit
Would like $175 + postage
Barry
0414 872 848
Abbotsford
[ Edited on 9-9-2006 by Bizarre ]
