L Bug speedo
https://forums.aussieveedubbers.com/threads/563/l-bug-speedo
Buger Gary ·
My speedo works but my oddmeter stopped.I pulled it out today and dismantled it. I found that the small plastic gear on the end of the number spool has cracked and is slipping.Does anyone know if you can get this part or a kit. It is a VDO kph in a 74 L Bug.
aussiebug ·
Gary,
The broken plastic drive gear is a common problem with later speedos - the earlier ones all have a brass gear there.
It can be rebuilt with a brass gear by any competent speedo repair place, and I'm sure someone here will tell you where it can be done (I know a few places in the US, but not here in Aus).
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.geocities.com/aussiebug1970/
There was a bloke "Phat73" - i think on STF. He would rebuild them. More to the point he did screen printing and the different faces he could put on a speedo were amazing. White background was good, so was carbon fibre effect looked great
If you wanted i could find his address
Buger Gary ·
That sounds great, But I'm pretty happy with the original for the moment I just want to get a cog if I can. I ended up super glueing it on to get it going for now. the only problem is the crack put the gears out of alignment and I had to trim them up with a stanley knife a bit to get it to work.It's going ok at the moment but I don't know for how long?
vwrallycar ·
hi yeah there is a VDO dealer here where i live that will repair them. try your local VDO dealer
The broken gear is a common problem and ive found the best place to get the speedo repaired is in Sydney at St George Instruments in Carlton 02-9547-0855
Buger Gary ·
Thanks fellas I'll try the Sydney number when I finish my 12 hour night shift round. Living in the far NW of Tassie I find we have no local dealers so every thing has to be ordered in most fo the time and once you have ordered it your usually stuck with it. Another problem is I use the Bug every day for for every thing so I can't just pull it out and send it away to be repaired. THe law might not take too kindly to me driving arround with a hole in my dash and estimating my speed.I'll fill ya in later if I have any luck.
Gary🙂
Why worry about that i didnt i just had my speedo calibrated by Barry at St George for the past few days...
