bajachris88 wrote:might start saving up parts and creating a collection for a future motor.
Thats probably the best idea IMO.
More rpm on a stocker isnt going to give you any more power it will just kill it quicker. Valves will float at higher rpm as the springs wont be able to keep them under control and as previously said the stock crank isn't counderweighted either so no good for high rpm. You won't get much more power from putting on a 009 by itself either.
I've talked to various people on this subject in the past, ie cheap performance upgrades and its a can of worms because one thing affects another. Since you are starting with a 1500sp its a bit harder again.
Best thing would be to put those pennies towards a future motor, sure its tough waiting but at least you have something to look forward to. A simple 1600dp with dual kadrons, cam like an engle 100 or the CB performance cheater cam, decent exhaust, lightened flywheel and some heads that have been touched up slightly will get you moving quicker for relatively low $. While you're at it a counterweighted crank would be a good idea as would some HD single valve springs. You'll be better off in the long run, less likely to have a piece of junk that breaks something all the time due to mismatched parts.
Check out the classifieds on
www.thesamba.com/vw theres heaps of vendors on there selling new performance bits for good prices and freight is not that bad. Of course the local guys can be a good option too.
