1300 to 1640?
https://forums.aussieveedubbers.com/threads/56575/1300-to-1640
blutopless2 ·
just wondering how much power gain you would see between a standard 1300 and a 1640?
oval TOFU ·
not that much power, I think it's all about the torque - esp with the 1300 gearbox, it'll be less of a chore to drive in traffic..
blutopless2 ·
getting it started this week.
engine is out of car and ready to be stripped.
then have to decide on carby and manifold type and whether i need new heads.
plan is to be back on the road by the weekend.
lugnuts ·
I went from a 1300sp to a 1600sp and it was great then i added twin baby webbers :o and it was a totally diff car:kiss
hellbugged ·
yeah, i went from 1300 to 1640, totally worth it.
saves dropping a gear in many places/situations
blutopless2 ·
original motor is a 1300tp
oval TOFU ·
by the weekend huh? you work fast! (or you mechanic does.. haha)
blutopless2 ·
haha... mechanic... they are stripping today, rebuilding today and thurs... back in car thurs arvo then hopefully ready to pick up on fri....
i'm not allowed to work on motors anymore.....
oval TOFU ·
that's because you have some adversity to torque wrenches...
lol
blutopless2 ·
i used my torque wrench... just didn't have my arm set right... 😁
blutopless2 ·
well should see for myself tonight as it is going to be ready.
was original 1300 tp motor
changed to 1640 with p&b kit.
host of new bits and pieces to finish it off and hopefully make it go better.
cant wait. 😁
will go just like a 1600...! :thumb
blutopless2 ·
got the car back last night... runs pretty good.. am happy with the extra hp and torque.
can really feel the difference in acceleration.
put some Kadrons on it and you will have the same "jump" in power again............well worth it.
lugnuts ·
Yeah what ^ said.:thumb
oval TOFU ·
good to hear it's all going good Rod. What else did you get done?
So Jane's behaving now huh?
blutopless2 ·
well she is much better than before..tho coz of the second hand carb she has a slight flatspot off idle...
initially i wanted to put twin kadrons on it but the mechanic told me it would just be too much for the engine and it wouldn't run properly.... ??
anyway... the work she has had done is...
new heads
new push rod tubes
new inlet manifold
new carb (did not arrive in time so have a second hand one for the running in stage)
honed barrels with new piston rings
new exhaust
lightened flywheel 200mm
new clutch 200mm
so just running it in till the first service.
I hope it got new bearings...?!
will need a headtorque and oil change at its first overnight cool-down or 500km
[ Edited on 23-9-2006 by VWCOOL ]
blutopless2 wrote:initially i wanted to put twin kadrons on it but the mechanic told me it would just be too much for the engine and it wouldn't run properly.... ??
Kadrons are fine on a 1600.
Lightened flywheel on a standard 1640 is not really a good idea, the motor needs the weight of the flywheel to maintain torque.:thumb
