Broken Clutch tube
https://forums.aussieveedubbers.com/threads/56597/broken-clutch-tube
ringoschariot ·
The clutch tube on my 67 beetle is broken. is there a easy way to repair this or will i have to cut open the tunnel and weld in a new tube?
You can use a hole saw to cut open the tunnel near the brackets that hold the tube in place
Only problem is you need t oknow where to use the hole saw
I would take the car to a place that has done this job before
ringoschariot ·
I can see that its the brackets that have broken and not the actual tube.
beerdoc ·
Thats good
Just do what vw54 said
Make sure if you do weld tube do not blow through preventing cable access
Good Luck
