speedo car pics
https://forums.aussieveedubbers.com/threads/56611/speedo-car-pics
speedo ·
hello i thought i would put some pics of my car on before it goes ito storage for a year , i am coming to see you lot down there for a time 😵‍💫and hope to take in some shows aswell as buy a camper to tour about , i have to say there are some insparational cars on here aswell so hopefully if i see any in the flesh it will give me the kick up the backside to start on stage two when i get home
anyway enough talking.... some pics 🙄
cheers jon
[ Edited on 19-9-2006 by speedo ]
hellbugged ·
speedo wrote:it will give me the kick up the backside to start on stage two when i get home
yeah, it looks like you have been a bit slack on that car of yours:P.........would you like to bring to bring some of those running boards for me too
speedo ·
the running boards are from remmele-motorsport.com they would post them out and they weigh 500g each so would not be expensive ,
would put them in my backpack if it was 4feet long 😂stage two is a new suspension setup as i am running a turbo motor and lets just say there are times i nearly
plop my pants when it lets go 😂
:jesus........ i think i'm in love
malcolm ·
hows the cae shifter ,is your car on germanlook or bugtalk forum
whatnow ·
thats very very nice. are you uk based?
pete wood ·
malcolm wrote:hows the cae shifter ,is your car on germanlook or bugtalk forum
wow, I like that. Who made it and where do I get one?
Flintstones ·
Very nice indeed!!
Any more shots of the engine setup?
Looks like it's turbo if I'm not mistaken
ruckus ·
Damn that's hot! Any more details/specs?
speedo ·
Thanks for all the replies,i will try to answer all the questions,the car is on the germanlook forum,a good source of technical info.
the cae shifter is brilliant ,i had to add an additional plate to the base to stiffen it up but it now works perfectly and only 1.5-2" of throw between gears .
The shifter can be bought at http://www.gwd-weiser.de/index2.htm if you go to the news tab on the right and scroll down the first page .
the car is turboed it has a garret t04-60 hybrid mounted over the gearbox there are some more pictures on this germanlook threadhttp://www.germanlook.com/Forums/showthread.php?t=7136 unfortunatly the car suffered a bit of detonation the other day and split the no3 cylinder so it's not running at the moment (gives me a reason to take it apart when i get back ):P anyway i am flying to thailand on tuesday 3 oct into a miliatry coup so the car is least of my worries at the moment 🙁
cheers jon
[ Edited on 20-9-2006 by speedo ]
malcolm ·
the shifter company http://www.cae-racing.de/
CAE Automobiltechnik Essen - CAE Racing - Prototypenbau - Rennsporttechnik - Kleinserienbau
got a quote it works out to be around $800-$900 aus.
speedo I replied to your post on germanlook user name 56oval.:thumb
speedo ·
cheers malcolm, i am following your build up with great interest as am planning somthing similair at a later date , i have to say all credit to you that is a very impresive project you have started on and a great scource of inspiration 👍👍
cheers jon
squizy ·
Dude you don't need any kick up the backside after sharing that with us. Beautiful.
matara ·
Love the car!
Hey, can you tell me how much oversize your wings are? And can you tell me what mods you made to fit the porsche hubs and brakes onto the front! Did you have to narrow the beam etc?
I'm slowly building a GL on a 61 cabrio on an IRS chassis,
Judsons4eva ·
Did you make your air cleaner ducts or purchase?
If you made them have you got a spare pair?
Dasdubber ·
Judsons4eva wrote:Did you make your air cleaner ducts or purchase?
At the risk of misunderstanding what you were referring to....the housings on top of the thottle bodies are actually part of the turbo system and the pipework is so the forced induction charged can be routed to the right place. Nothing to do with air cleaners though (my apologies if you were referring to something else). :thumb
By the way, what sort of fuel injection setup have you used? You car is fantastic - I've seen it on germanlook forum and drooled over it already!
Judsons4eva ·
I understand what the inlet system on a turbo must do! But I am interested in the housings in the top of the throttle bodies.
speedo ·
Judson ,the housings are the standard c.b Pertformance pressure pots ,i reversed them and used 4 additional hold down studs to stop leakage ,eventually i am going to make some custom pressure pots in a y formation out of 2" tube but got a world tour to get through first :P
Das at the moment i am running a cb system with 400cc injectors and ignition off the dissy ,the injectors are to small so have got some 660cc :thumb injectors ,i have seen an ems stinger system made in oz which you can use ford ztec sensors and coil packs so i may be making a purchase (girlfriend won't notice a little box like that in my rucksack will she ?):P , hopefully with all the adjustment available i will not split another barrel (detonation )
Matara i used porsche monoblock calipers off a 996 c4 , i narrowed the beam 2" used cb 2"dropped spindles and for the hub carrier i just ordered a set of front disks with porsche pattern, aftermarket disks are thicker and dont have webbing .I turned the disk off it and used it as the carrier for the porsche disks , bought some 40x40 mm ally square bar and then just mock them up on the disk and drill the holes to suite , the first one took 6 hours the other 3 took 1.5 hours each the rears are v easy if you use porsche arms the wings are 60mm wider on the rear and 30mm on the front ,they took a while to get used to but i now think it makes the car look like a huge vampire bat out for blood 🤪
anyway i hope this helps feel free to ask anymore questions
cheers jon
[ Edited on 21-9-2006 by speedo ]
Flintstones ·
Speedo,
do you have a firewall to keep the heat from the turbo/exhaust out of the engine bay?
speedo ·
no i don't but then there is no heat at the back of the engine where the fan is as the heat is all above the gearbox ,i installed an extra cooler so there are two and the car will sit at 80mph all summer long 😵
bond ·
i didnt look at this thread as i thought it was pictures of peoples speedometres......... ahhh dear.... lol
glad i did now though - stunning ride mate!
nick
Fossil ·
Feak'n Luvley 👍
1916 ·
yeah mate awseome ride..if my plans all go well my ride will look somewhat like yours.
fenrayer ·
You do have a sweet ride , and best of luck and stay safe in thailand
thoughts are with you
gull ·
cool ride
Lams ·
kickass 👍
