new car, just did valves, plugs, timing etc . sounds nice but is now idling at 1500 looked at the dual kadrons left one will not sit on the idle screw until a gap of 3mm with carb body, left one adjusts down to nothing (or there abouts) the linkage has a brass nut and a 'locking' washer and won't budge, the link to throtle has a number of adjustments and is not the cause of the problem.
does this nut at the back have a impact on how closed carb is when idling? can it be adjusted?
does any one know any roads where there is no traffic and no stop signs so i can have a drive?
you need to be able to adjust the length of the cross bar between the carbs.
Its always hard helping people set up duals
There are a 1000 things to set up
Have you balanced the carbs? - this is the FIRST step before anything else.
there are a few help sites there that will answer a few questions.
Not being rude but with duals you have too choices
1) read read read and learn the hard way grass hopper
2) hand over fist fulls of $$$
bug eyed ·
craig- problem is not crossbar it is where that bar attaches to the carb, brass arangement 20 cent size with a thread and nut poking out the back it wont allow the idle screw to return fully
jim i'm looking at that page now , i will report back
thanks to both of you
Have you taken the "bar" off the carb ? this will allow you to set up both carbs seperately. they should close with this bar off. What usually happens is the bar is too long/short and it holds one carb open!
bug eyed ·
yes , even with the bar off the left carb wont close down so the screw touches the body. that's what the problem is, the left carby throttle off setting will not adjust down further than 3mm so when i balance the idle setting it's about 1200
bug eyed ·
one 15 minute phone call
5 minutes work
all fixed
expert: stan the man pobjoy
and the problem was??? 😀
Baja Wes ·
Barry, have you changed your name to Jim? :p
my guess would've been something stuck in the stop on the back side of the carb.
My spark plug lead decided to get stuck on the backside throttle stop on my webers one day, made the throttle stick half open. nice adrenalin rush.
Baja Wes wrote:Barry, have you changed your name to Jim? :p
Jim Junior :bounce
Throw them in the Carbage, together with the Monza exhaust systems !!!!!!!!!!!!
