ej20tt drivers wanted
https://forums.aussieveedubbers.com/threads/56784/ej20tt-drivers-wanted
mo 1303 ·
Had some one of you an ej 20 tt (h) engine with 4 connectors at the ecu ?
I needed the pin out from this ecu !
Can some help me or have an idea where to get it ?
Thanks guys !
seagull ·
http://www.tactical-bus.info/subaru/LegacyWiring.html
boof2332 ·
I have an ej20tt...can you post a pic...do you wnat to know where the 4 wires go?
Matt
seagull ·
I have a EJ20TT as well
206 kw
mo 1303 ·
thank you guys!!!!!!
so much !!!!!!!!!!!!
i will read it tonight !
I hope it help me !
the stupid thing is for an ecu with 3 connectors is a plan at home but for 4 connetors at the ecu ..... no way....
pics from your car ? please !!!!
i´m very interested!!!!
mo 1303 ·
i checked the plans but i have a question !
the plans are for double coil not for single coils and electric for the vacuum valves for the second turbo are missed !
do you have other plans or do you know the way of wires in your cars ?
thanks !
gull ·
http://au.geocities.com/twinturbosubaru/
1916 ·
i heard the ej20tt's have a terrible lag in between the first and second turbo spooling.
definately wouldnt be my choice of engine
seagull ·
Thats the problem
you heard it
Mates has 223kw at the wheels
1916 ·
yes but power isnt everything neil...you should know that.
also rode in a liberty b4 which had one of those ej20tt's and witnessed it myself.
mo 1303 ·
if you had a aggressive typ1 or typ4 with an aggressive cam and go to the limit from the engine, i thing it´s also nothing better .
they runs under 3500-4000 no good .
so i think it´s not a realy problem with the tt.
if the lag is to big , i choose to paralel turbo.
1916 wrote:yes but power isnt everything neil...you should know that.
yeah I tested these cars when they were new and it SUCKED
1916 ·
yeah. im not trying to turn you off your conversion though mo1303 as im sure you could get it tuned out just saying my experiences with them and stock ecu.
mo 1303 ·
it´s not the easy way with stock ecu .....
but i´m frightend for aftermarket stand alone systems.
is the cold start and the idle with aftermarket ecu good .....?
what do you think ,what aftermarket ecu is good for subi engines ?
1916 ·
theres a whole host of aftermarket ecu's. microtech is probably the most widely tuned ecu out there.
