mattie182 wrote:well,
I have the tank at the front, a low pressure pump feeding the surge tank also at the front. I would prefer to have the HP pump at the back, really only because of space
Mat
Nah...heaps of space.....I did away with the surge tank,low pressure pump etc when i got the larger fuel tank made. Now the tank outlet is directly above the high pressure pump and the return directly to the tank. It looks a hell of a lot neater now. You can see the low pressure pump near the master cylinder and the high pressure one on the passenger side. All lines are high pressure stainless inside the tunnel to the motor at the other end.Fuel filter is at the rear near the engine. I wanted to minimise the possible amount of "leak points" at the engine end and wanted acess to the pump/filter easily if needed. HTH.
