Im building a baja to be road registered and am going to have a roll cage. umm front and middle hoop, no support to the front, rear cage connection.
Anyway. will i have any problem trying to register the car with vicroads if i have a roll cage with an engineers certificate? Or should i wait and do it after the registration?
Ant
70BAJA ·
sorry can not help you with VIC but in QLD you need a engineers cert with a blue plate attached to the car.
the roll cage needs to be padded in the head strike zones as well as other things
neil
beetle from hell ·
Why do you need blue plates? And are the plates the number plate or a seperate plate?
Im gona have padding in contact zones standard and will be getting an engineers cert at least for the knowledge when a copper pulls me up.
A blue plate is a modification plate attached to the vehicle to certify the modifications are engineer approved.
Thanks for that Hellbus. So as long as the roll cage is properly constructed and sound i should be able to get the VASS cert, and having that, the registration should go fine? Excellent.
