Can you guys give ma an idea as to the weight of a 1960 bug .
this is in Drag from , all the weight out of the car
dangerous ·
I think standard weight is 720kgs wt.
Mine is about 805Kg with Pauter, bus box and cage(with me).
Most of the cars can be lightened for racing. Lightest Pan car with a beam front that I know of here in Australia was 1430lbs with driver...650kg.
empi ·
later models are around 880 kgs , there should be some indication of weight on the compliance plate.
malcolm ·
these are standard weights
1945 onward 721kg
1955 onward 726kg
1200from 1960 730kg , 1300 760kg, 1500 820kg
1970 1302,s 825kg, 1303,s 862kg
these are from a book by David Hodges.
I have a 1967 1300 glove box owners manual and it says 1638 lbs or 742 kgs.
seagull ·
interesting stuff
I have been striping just about every steel clip off the bug .I have even machined the rear horn bolts down & out .
Nothing gets put on the bug with out total thought of weight
