what Joel said ,its a long way from the reg to the ammeter and back so you need to use big arse wire and be certain to avoid anything that might rub thru the insulation and also try to put the cables inside some convo tube and solder the terminals to avoid losses ---------MUCH easier to use a voltmeter ,and just as accurate .
