Country Buggy Steering Wheel Questions
https://forums.aussieveedubbers.com/threads/57024/country-buggy-steering-wheel-questions
Nevada51 ·
Does anyone know whether a country buggy steering wheel will fit the steering column of an Oval? I seem to recall someone saying the splines were different or some such issue.
Pehaps a more broad question should be are country buggy steering wheels essentially the same as those found on Standard split beetles, or are they different?
as far as I can see, they are the same as early beetle
splines should be 49-67
edit: I'm not sure about shaft changes but I assumed that being a '68 car with a 49 steering wheel they'd be the same up to 12V
[ Edited on 4-10-2006 by VWCOOL ]
shaft sizes came up in a thread a few months back but from memory bugs upto 60 are the same
i know 61-73 are the same and 74 on is the tapered kind same as watercooled cars
-Joel
Matt Ryan ·
I've been told by a country buggy owner that the steering wheels were sent out from germany to use up very old stock from kubelwagens. Do some research, If that's true then the steering wheels are probably quite valuable.
Matt.
ur probably right Matt theyre the same as kubel wagen and split bug so they would be worth a bit
even just crappy 2 spoke 60-71wheels have been going for over $50 on ebay latley
-Joel
They used them on weird shitters like post vans too
Nevada51 ·
Thanks for the responses. There's a wheel I was looking at but the owner reckons the spline count is different to that of an oval. Not sure what to make of it given the above info - me thinks I'll pass on it.
MikeM ·
Where is the steering wheel? I have a country buggy without a steerign wheel. I'm interested if you aren't.
BUGBOY ·
I have a few and they will fit an oval beetle spline.:thumb
Nevada51 ·
MikeM: have u2u'd you the details.
Nathan - thanks for your input - I was hoping you'd chine in given you've got a CB and oval.
nbturbo ·
BUGBOY wrote:I have a few and they will fit an oval beetle spline.:thumb
You wouldn't have spare a horn button you could sell???
