Pulled the engine out of the Vee the other day.
The suspension steering and brakes are sensational but the engine just lacks any ooomph! Plenty of revs, 6700@ valve float but just no grunt.
So pulled the engine with a view to taking it up to a M8 to do the cam timing.
Its carrying 3.5 degrees retard along with the big carb throat, short header pipe lengths and radical valve geometry and is set up with the likes of Phillip Is in mind where the engine performed well.
I pulled the oil pump and the rest of the paraphernalia off and had a look at the cam gear.
For whatever reason i rotated the crank a bit and the cam was not following as it should????? In fact winding the engine over with no plugs resulted in some ominous "clonks" at various intervals...................
Bugger it, there is about 0.50mm backlash in the gear!!!!!!!! yep, about .040".
Along with the 3.5 degrees of retard dialed in to the cam results in quite a bit of cam retard.
Interesting thing is that the tooth backlash varies around the circumference of the cam varying from almost nill to half a mm depending on the area of mesh????????
Anyway, needs a cam gear to start with so strip the fucker, first thing off is the ally sump extension and the remaining oil in the bottom is all nice and reflective........................(this is going to hurt).
Anyway, pulled the entire engine down and the cam gear and crank gear are badly worn, the cam bearings are lunched and the rear main bearing has eaten some rubbish and is worn and badly scored. Fortunately, the crank is undamaged.
Thought id better check the big ends and they are pretty sad as well altho the crank pis are spotless.
Some days its not woth getting up!
So, Im clobbering up a bastard of an engine with my old bottom end and my new top end.
I advanced the cam timing 1/2 degree from stock and Im using my longer 1&3/8" pipes along with my smaller carb. The radical rocker geometry has been calmed down with a set of shorter pushrods and different rocker shaft shims.
Motor will be assembled tonight and hung back in the chassis on the weekend.
L8tr
E
L8tr
E
tassupervee ·
