I know FLAT SPOTS have been gone over a thousand times, but I can't find anything relating to my particular problem.
I'm running a 1200 with a 30 pict-1 carb and an 009 dizzy. I've set the plug gaps, points gap and static timed it.
After doing this, I had a major flat spot trying to accelerate away from a stop. I thought it was the carby but couldn't find any fault with it. Playing with the whole set up, I just advanced the timing while the car was running until the flat spot dissappeared, which it did with massive advanced spark.
This leads me to believe that the problem is not in the carby (the accelerator pump would cause a flat spot all the time if it was playing up, regardless of timing) and there should be no other reason for it.
I'm really worried about excess heat from such advanced timing but I hear that the 009 dizzy requires advance of 30* when all in.
Any suggestions greatly appreciated.
Thanks.
Ross.
Split nut ·
