Well my bus is up and running but my fan (ECU controlled) is coming on at 85°C. I'm sure it's meant to come on at 95°C. It turns off at around 78 🤪
I borrowed a calibrated (standard) digital termometer and attached the sensor to the heater outlet from the water manifold. There's no matrix fitted, just a straight 4" loopback. Measurements taken with van static.
It was easy to see when the thermostat opened (started at 76C) as the temp leveled out. Temp peaked to 85 and the fan came on. Ummmm.
I'm not sure if my doner had AC but there were both AC and Main fan wires from the ECU. I feel sure I wired in the correct one.
(I could not find a correct wiring diagram anywhere & had to buzz out the whole ECU pinouts.)
Any ideas?
Apart from that she goes well, very well 😀
Gotta sort some heating soon as it's starting to get a bit chilly in Blighty.
ElusiveStranger ·
