1st and 2nd gear problems
https://forums.aussieveedubbers.com/threads/57428/1st-and-2nd-gear-problems
Learner ·
hey people i hav problems with 1st and 2nd gear. 1st pop's out and the 2nd get stuck if selected while at stop. and also (sorry my english is not greate but i'll try to explain) is it normal that when you shift down gears to over take it grinds? is there anything i can do about it?
thanks heaps
dangerous ·
Sounds like a pretty major internal rebuild is in order, BUT.....
Have a look at your gear box bounts first incase the tranny is moving back and forth, causing your ailment.
Learner ·
ah no. that's tlaking major $$$$$!!! i probably haven 100 to my name!. alright thx i'll take a look
havea look at the shift plate under the gear stick maybe its not fitted correctly or needs adjusting to the correct position
If you dont knoe how its susposed to go then take to a good VW shop for checking
then look at the gear shift universal joint under the rear seat
then look at the front and rear gearbox mounts etc etc
Learner ·
thanx mate i'lll have a look if i can't like u said i'll get it to a shop
