tdegens ·
What size is the rear engine oil seal as I have to put a new one in. For Beetle motor.
https://forums.aussieveedubbers.com/threads/57445/rear-oil-seal
tdegens ·
Volkswagenboy ·
tdegens ·
xornge666x ·
Commonly known as a rear main seal or flywheel seal...68AutoBug wrote:You mean the front engine oil seal behind the flywheel.
as the rear of the engine has no seal...
monique__d ·
type3lover ·
greedy53 ·
Yes thats great advice from Tobytype3lover wrote:Yep get the red one from a VW dealer for your motor. Under $10 I think!
When fitting I use a smear of permatex on the outside diameter and a smear of engine oil around the lip. The oil is important.
Also change the flywheel o-ring as pictured above.
Good luck! Toby 👍
