What to clean a fuel tank with???
https://forums.aussieveedubbers.com/threads/57450/what-to-clean-a-fuel-tank-with
gerbie_rox ·
Hey guys,
Tryin 2 clean out the fuel tank in my hilux. What can i use to flush it out with? Just fuel? Also the tank is still on the car as i cant get it off. Have taken the bung out so yea it can all drain that way.
64vwmark ·
Metho would be good to use. If there is any moisture in there it will remove that too.
i use a few litres of metho and a handfull of washers or nuts or failing that some blue metal (marble size or bigger)
obviously this will only work if u can get the fuel tank out
if u cant back the only other method i've seen was steam cleaning the inside for about 24hours
but that was done from a hugeass boiler
-Joel
