get new spring plates cut ? not sure im down 3 inner splines and i dont need em 馃槈
Hertz 路
Bugboy is making them.
oval TOFU 路
pyr0 wrote:get new spring plates cut ? not sure im down 3 inner splines and i dont need em 馃槈
Is that because you like to replace your tyres every 10000kms? 馃檪
I lowered mine about 2 splines and it's scrubbing from too much toe in..
oval TOFU 路
I might be interested.. unless I get the better equivelants off bugboy later on down the track...
pyr0 路
nah im not scrubbing, im running 165's on the rear and 135's with a 2 inch narrowed on the front, havent scrubbed yet 馃槈 but your right its got some wicked camber :P
[ Edited on 16-10-2006 by pyr0 ]
Hertz 路
Might no be rubbing on anything, but i bet she toes in like a bitch. Better off getting em off Nathan. Keep your money in Australia and support a local.
MikeM 路
Anyone got a link to a thread where Bugboy is selling them? Does anyone know where we can get the Z shaped lowering spring plates to keep you rear suspension travel stock?
[ Edited on 16 October 2006 by MikeM ]
rupewrecht 路
MikeM wrote:Anyone got a link to a thread where Bugboy is selling them? Does anyone know where we can get the Z shaped lowering spring plates to keep you rear suspension travel stock?
ditto!
Hertz 路
there is no thread, just shoot him a u2u.
Hertz 路
those z shaped ones are available from red9design in the us. big big bucks, and when u think about it, its the same as running notched plates with extesions, just stronger i guess. ride will be no different.
MikeM 路
Hertz wrote:those z shaped ones are available from red9design in the us. big big bucks, and when u think about it, its the same as running notched plates with extesions, just stronger i guess. ride will be no different.
while giving much easier adjustment (as well as being a complete replacement), theyre also more expensive (naturally).
hmm
VWCOOL 路
If you can't afford to pay, you can't afford to play...
Hertz 路
Those are not springplate extensions, they are adjustable springplates which are stock length. The springplate extensions he did were exactly the same as the ones you spotted on the samba. As i said there is NO thread, just u2u him if you want an idea of cost. Adjustable springplates help you to adjust the ride height, while spring plate extensions help you to adjust rear toe in/out. Springplate extensions wont make your ass low, they will stop it spearing off the road in the pissing rain, once it is lowered.
[ Edited on 16-10-2006 by Hertz ]
ren 路
Hey Nathan, care to chime in with a price for your extensions? I might be interested down the track too....
oval TOFU 路
Correct me if I'm wrong, but he may have extended them in foresight to the toe-in problem.. i'll let you all know when i find out..
Hertz 路
One compliments the other.
rupewrecht 路
oval TOFU wrote:Correct me if I'm wrong, but he may have extended them in foresight to the toe-in problem.. i'll let you all know when i find out..
That's what i was led to believe as well, hence why i posted them. If not, so be it.
