Long term street/strip project - EFI/turbo advice?
https://forums.aussieveedubbers.com/threads/57654/long-term-streetstrip-project-efiturbo-advice
Dasdubber ·
Now the ragtop beetle has left the stable (see next issue of VWMA), I was fortunate enough to acquire a nice notch (daily driver) and an oval as part of the trade. Although my wife won't be too happy about my plans, I've decided to take it slow to not blow the budget (again).
Anyway, after the warwick weekend (my first drag racing experience) I am well and truly hooked so my attention now turns to a street/strip project (hence the oval).
I've been inspired by the cars like Rod Richardson's (Raz34), Dave Becker's and Morgan Smith's beetles (not to mention countless others) and therefore want a tough and traditional (to a degree) "looker".
Here are the pics, more blah blah below. (here it is coming home)
[ Edited on 12-1-2007 by Dasdubber ]
Dasdubber ·
She is a nice solid old girl so apart from some firewall mods (maybe) it will stay as is for quite a while. The limiting factor for plans will be money - I've just started up a new business and it will be a while before it starts turning over a profit, however I need to keep dreaming to keep the motivation alive!
I kept the type IV out of my ragtop so that will eventually go into this oval however its stock cam and heads are limiting the fun significantly! In terms of advice I'll ask the questions below:
Plans are to eventually (when $ permits) strip the type IV down, keep the 71mm crank, stock rods, flywheel etc as is to save a few dollars, keep the case fairly standard and change the cam and do some head work.
Option 1: bump up displacement via 103mm p&c's (have researched a fair bit already re. head sealing issues), keep it naturally aspirated (not sure if the 40 dells will suffice), change cam perhaps to something like webcam 86b, and try and get the heads to flow a little better.
Option 2: keep p&c's at 94.5 along with internals (maybe ARP rod bolts for strength - again not sure if needed), modify the current header to suit a turbo application. Again $ will restrict how far I'd go, but of course then dual FI throttle bodies could be integrated as well.
Option 3,4,5 etc etc - of course the options are only limited by money and time....I'll post a little more info below to give you an idea of what I hope to achieve.
Dasdubber ·
At the risk of writing a 5000 word essay, I'll try and limit the blurb to relvant info only. Ultimately (eventually) I'd love to run 11s, and more realistically 12s until cash starts to flow a little better - I want to have it street registered but not necessarily to do any 100km runs up the coast etc.
For now since I have a fairly solid type IV base I'd like to keep its stock stroke etc and play with heads, cam etc for short term improvement in ET's. Down the track I will reassess type I vs IV etc....basically trying to keep the $ outlay as small as possible over the next 6 months whilst business picks up, then I might have a bit more to play with mid next year (hopefully).
Current exhaust:
During exhaust construction (I understand there could be problems with mounting a turbo so low though (presuming the muffler is eliminated and flange modified) - oil return issues etc?
Dasdubber ·
Any advice is appreciated - I need to talk about gearboxes as well but will keep reading before I ask any more specific questions (obviously the NA vs turbo equation will affect ratios etc).
Perhaps initially just a new cam, and head work will get me on the track any maybe into the 14s? Save the coin and build a more serious engine after funds allow?
Alan
dangerous ·
Hi Alan,
Welcome to the dark side, there is no return you know!!
I (and I am sure others) would be happy to give advice, and time, into your project.
Good basic drivetrain investments, like axles and tranny are a good start in a project like this.
The engine will be a project that evolves with your need for speed,
so you can start with what you have and progress from there.
If you aim for reliability and consistency, fast times will roll in.
DB.
ruckus ·
Nice 54 Alan!
Obviously I can't give any advice, but I eagerly await the outcome as I've loved learning from your approach in the past.
Good luck with it!
Dasdubber ·
Thanks Dave and Rob - any advice or words of encouragement are always appreciated....you'd be surprised how many times I wanted to stop work on the ragtop during the resto but the comments from people such as yourselves kept me going!
You are right Dave, I want to build a really solid base (ie. gearbox, axles etc) that will handle mild power to start with, but also deal with some more hp later on.
Likewise for the engine - basic to start with, but if I did end up going EFI etc, I'd like to carry those parts onto a bigger engine down the track.
Cheers 👍
nbturbo ·
Alan-did you catch up with Adam Debiasi at Warwick-he had a 2.5 Type4 in a 57 Beetle.You couldn't get anything more streetable than it,and it's capable of low 12's.When he put the motor into the 57-he told me that his first run was a 12.5 with all street running gear-really surprised himself.
Aussie ·
Dasdubber wrote:She is a nice solid old girl so apart from some firewall mods (maybe) it will stay as is for quite a while. The limiting factor for plans will be money - I've just started up a new business and it will be a while before it starts turning over a profit, however I need to keep dreaming to keep the motivation alive!
Looks like you have got a decent base car! Any other pics?
Dasdubber ·
nbturbo wrote:Alan-did you catch up with Adam Debiasi at Warwick-he had a 2.5 Type4 in a 57 Beetle.You couldn't get anything more streetable than it,and it's capable of low 12's.When he put the motor into the 57-he told me that his first run was a 12.5 with all street running gear-really surprised himself.
Yeah I had a good chat to Adam about his type IV - the big challenges are obviously head flow and exhaust stub port restrictions (can't go too big since they have to fit between the push rod tubes)....to keep costs down initially I will probably keep my current headers though. I love the torque of the 2L type IV already so I'd love to see what it feels like when bumped up a bit!
I'll try and get some more pics soon.
Alan
bails ·
alan ,tell me how you do it. you must have 36 hours in your days. looking forward (again) to the build. here's to mid 10's. :thumb
pete wood ·
Wayne Penrose had some stuff on his turbo oval post about getting bigger primaries in between the pushrod tubes.
Also, depending on what access you have to a machine shop, EFI throttle bodies and manifolds can be made using existing throttle bodies and a bit of nous. I saw a Jag 6 in Zoom a while back with 6 camry throttle bodies all ganged together and injectors spraying right into the bell mouths.
You could also modify type 4 EFI manifolds. I've got some and having had a look at them, it can't be that hard. I know the weber stuff is easier to bolt on, but it also costs an arm and a leg.
whatnow ·
not trying to rain on your parade, but wouldn't it be more sensable (though no where near as cool) to get something like a 60's 6V shell so it doesn't matter when you gut it completely, chop it for removable valance to clear big carbs or FI and then weight reduction, fit extra/larger fuel lines, traction bars, fit glass panels and lexan etc
someone on the cal-look forum once said that 50lbs weight reduction = -.1 et on the strip.
stripping out the interior of a car plus bumpers sound deadening etc costs nothing and should see a noticable drop in et's over the blue car and you still get to have a beautiful oval to cruise in on the weekends.
i'm sure there are plenty of people who would be happy to off load stuff your direction just for the pleasure of watching another dasauto being created... on that note you have a u2u.
Dasdubber ·
Cheers for your thoughts re. alternative beetle/shell to use to maintain the integrity of the 54. I do appreciate it and also have thought about it many times (hence why I haven't posted any details of this oval up until now despite owning it for a few months). I guess there is always a risk that some people will be upset about making a street/strip project out of such a solid old oval, however my justification (not that I really need to justify it to anyone other than my wife!) is:
1) space restrictions - I already can't fit all my cars at my home (have to pay storage for my splitty) so I couldn't keep the oval and start another project (and I don't want to sell the oval);
2) I couldn't justify a pure drag car to my wife and not be able to enjoy it on the streets (even if just for short trips around the gold coast where I live);
3) I always like to do something a little different and the oval provided such an opportunity as there aren't too many on the strip in Oz at the moment (of course there are exceptions like Wayne Penrose etc);
4) it is such a solid base, it will save me months of rust repair and structural work before I tackle the mechanical side; and
5) I won't be destroying the oval - any necessary mods will be subtle and staying in the taste of the old girl to maintain its integrity.
I haven't meant this to sound defensive as I know no-one was having a go (I am sure purists out there will cringe). Everyone has there reasons for following a particular pathway with their cars and what may seem sensible to one person will seem insensible to another...ultimately I will follow the pathway that suits my tastes, budget, and what is in the best interest for our situations (space, finance etc etc). Down the track (I mean way down the track), after I get it running at an ET I am happy with (although are we ever happy unless we are going faster?), I'd love to restore it like the Renn Kafer Cup cars in the US - best of both worlds (show and go).
Cheers, I'll post some more pics later hopefully.
Alan
[ Edited on 21-10-2006 by Dasdubber ]
555bug ·
If it was my decision I would supercharge your donk, quad throttle bodies in a carbon box like the Remelle cars. That was all the work you have done is maintained plus any cam changes etc. will be beneficial to power output which is often not the case with turbos. Best of luck I look forward to see her in the flesh at Warrick
hypo-vw ·
Hi Alan , good luck with your project 54' . I will be great to see some more quick ovals on the OZ drag strips , not to mention how great it will be to see you develop your own type-4 turbo engine .
I too believe that this is the way to go for extreme VW street performance in an air-cooled volkswagen , with the best reliability .
Go the 'big block' Veedubs.............
Dasdubber ·
Thanks guys. Wayne, seeing your oval at warwick (albeit briefly!) certainly provided more inspiration to see what the type IV can do (along with Adam's beige bug).
Just in case anyone was wondering what I was driving at warwick, this is the 70 bug which I've restored to sell shortly - I had my 2L type IV (stock cam, heads etc) in it for the weekend. Best was only 10.5 (taking it easy on the launch so not to break the box before selling the car!)....you could really feel the stock cam and heads limit it above 3500rpm!
dangerous ·
I think you can achieve what you want with out cutting up your '54.
These days, you can brace your forks with bolt-in stuff, and I would guess that with some engine tinwear trimming the engine will go close.
If you invest wisely in the tranny, you wont have to pull it out very often, so the rear apron can prob stay intact.
But it is only metal, you cant take it with you...
Sell that Blue car and start getting some tranny bits dude!
I think I can help in that department.
Dasdubber ·
The rear end has had a hit in the past (the stock 36hp rear tin barely fits due to the squashed side of engine bay)....so the removable rear apron was going to happen regardless (same as my old ragtop - you couldn't really tell unless you looked closely).
dangerous wrote:Sell that Blue car and start getting some tranny bits dude!
Cool Dave, I'll do a bit more reading to obtain some knowledge....then will post some more specific questions and will have a chat to you in more detail.
Alan
PS It has been resprayed so don't worry - its not original paint 🙂
pete wood ·
mmm, just waiting for something big and nasty in it's rear end...🤘
Aussie ·
Dasdubber wrote:The rear end has had a hit in the past (the stock 36hp rear tin barely fits due to the squashed side of engine bay)....so the removable rear apron was going to happen regardless (same as my old ragtop - you couldn't really tell unless you looked closely).
How are you going to make your rear apron removable? Got any pics of how you did it on your ragtop?
[ Edited on 22-10-2006 by Aussie ]
Dasdubber ·
G'day mate, here is a link to the pics of how I did the old ragtop rear apron mod:
http://www.manxgallery.org/gallery/album146
I guess my first real question would be in regards to turbo placement - I understand it is desirable to have the turbo above the case for oil return, do you think;
A) the current header could be adapted to either place a turbo down low (eg. changing the flange pictured and mounting the turbo near right side valve cover)?, or
B) mount the turbo in the engine bay and keep the current header as is but run a single pipe from the pictured merge up into the engine bay?
C) of course a new header arrangement could be ideal but initially I will need to keep costs down as much as possible by using what I have where possible.
Dasdubber ·
By the way, the oval will have it's back end much higher than the old ragtop so ground clearance will not be such an issue as it was in the old car.
Turbo54 ·
Alan,
I have been for a ride in Adam debs car and it is seriously quick. I even offered to swap motors with him. The induction noise will have you roped in in no time and it has run 12.02 which is bloody fast. You have all the right bits to do this. i would go this path for the moment and then think efi or boost. The 54 looks clean and untouched which is good. I have done mine with min carnage and saved weight with other things and carefull planning rather than hacking out panels. It can be done and everything can fit. Cant wait to see this one progress, if you have any questions about a 54 let me know.
T54
66deluxe ·
Alan, i am going to be doing an ARP rod bolt conversion to my 2 litre rods as i have about 4 sets of them and use chevy big block bolts they are basically the same as the ARP 914 bolts but cheaper and you get 16 instead of eight, i will then balance the rods end to end and hopefully get my mate at Boeing to shot peen them for me, another option would be to get a 71mm crank for Jake Raby with the type 1 journals these are only $275 US, then you could use any performance type 1 rod you like. Good to see the drag racing bug has hit, nice oval too. Cheers Damo.
dangerous ·
66deluxe wrote:Alan, i am going to be doing an ARP rod bolt conversion to my 2 litre rods as i have about 4 sets of them and use chevy big block bolts they are basically the same as the ARP 914 bolts but cheaper and you get 16 instead of eight, Cheers Damo.
Hi Damo,
You will have to drill and ream the rods to fit the chevy bolts, and they will have to be made round again (resized) either way.
I have used the ARP bolts for the T1 rods and they are superb, but yes, expensive.
I would buy direct from ARP, but do a phone-around to places like Rocket or Bill Mann( in Bris), they may have old stock, but dont let themsend you the wrong part number!.
The cost to drill and ream the rods, may outweigh the cost difference, and also the bolt head may need clearancing(not sure on this) with the Chev bolts.
Hey Alan, Keep that sucker N/A!
Save the turbo for the Notch!
Dasdubber ·
I think I will have a fair bit more time to decide which way to go Dave.
My initial thoughts are to do the car in two or three stages over a few years (although plans often change). First would be to retain the type IV and do a budget (again being realistic and not cutting corners) performance upgrade (hence why I'll keep my crank, rods and flywheel stock). If I keep the current p&c's, addiing a turbo could provide a short term way to get a few more ponies and have some fun on the strip. I'd like to build a box to handle more power though (for stage 2).
This could include either a totally revised type IV approach, or build a big type I N/A when funds allow. Who knows at this stage though.
I don't know if I ever will get to stage 3 but I'd love to have a car like the DRKC machines which would encompass a full resto to the quality (or better) than my old ragtop, but with the performance (from stage 2) to back up the looks.
Time will tell (and how much or little of the folding stuff I have at the time!). I got the oval running the other day - hard to contain its mighty 36hp powerplant but I resisted the urge to do any burnouts for now!
Dasdubber ·
I always end up writing too much so I'll try and keep it short.
I have sold my blue bug and had to sell the notch to keep some food on the table and the bank happy....so I am in the planning stage for oval upgrades (hopefully before warwick but not for a while).
My plan entails modifying the parcel tray/firewall area to accommodate a turbo (above the gearbox) and intercooler (similar to Wayne's oval but a much tamer version). Remember at the end of the day it is my car, so please resist the urge to tell me not to cut it - you know I won't do anything stupid or unnecessary 😉
I want to use as many of my existing components as possible (to keep costs down) therefore the base will be:
- stock 71mm crank and rods, slightly lightened flywheel, 94.5mm p&c's all balanced by crankshaft engineering before it was assembled the first time. (all in a 2L case)
- 2L heads with 1800 valves - this is an area which can obviously do with some big improvements in terms of port flow, possibly exhaust valve size - the current valves have the typical 3 angle grind.
- I plan to modify my current headers so they are reversed (ie. the merge will face forwards on the LHS of engine rather than backwards on the RHS as it stands currently). I would like to run the single pipe up over the g'box to the turbo.
QUESTIONS:
1) For a relatively mild engine like this, what sort of turbo recommendations are there?
2) I'd like to run a single throttle body and EFI - any suggestions I should start my research with?
I intend to use this engine as a learning experience so I want to keep the budget tight (within reason) - for example using second hand/reco'd turbo/throttle body/efi etc. I don't mind spending $ on components which I could potentially use for a bigger/better engine down the track (eg. ignition system). I just want to do as much as I can and learn along the way so when it comes time to go faster, I know what I am doing.
So don't worry, I know and agree with the general advice of do things once rather than twice....but this is the best compromise otherwise the oval won't see the strip for a couple years if I try and build the big engine right now.
Alan
cram ·
Good thinking reversing the exhaust! just need a big pipe up to the turbo and down again to the muffler..Also, I know you mentioned EFI, but why not go down the draw-through set-up path using a holley or side draft weber/dell? Would be the cheapest and easiest way to go turbo.
dont forget the brakes!
Flintstones ·
Dasdubber wrote:QUESTIONS:
Alan
Use a turbo off a VL or an FJ20/SR20 or somthing similar that has an internal wastegate (TO3) with a .63 rear or there abouts , get an XF throttle body, they're cheap as.
Get a liberty water to air intercooler and some series 4 13B turbo injectors, and that will get you a good start.
Dasdubber ·
Thanks for the advice thus far guys. I guess it will kinda be a bit of a "junkyard turbo" build up. As I said I'm happy to invest $ in parts which I can use on a latter bigger engine.....also I won't cut corners on getting the rest of the car sorted (ie. will discuss g'box in detail when the time comes, chassis bracing, new fuel lines (and return), brakes (discs up front, type III rear).
I am looking forward to seeing what sort of combination I can come up with and more importantly see what sort of numbers it can make on the track!
Dasdubber ·
Alright - its starting to get a little more 'street cred' with the narrowed beam. Dual circuit m/c is installed.
So far I have the following suggestions for turbo/efi (thanks flinstones):
I've had a bit of a look into it already, are there any other ideas?
I would like to invest in an ignition system that I could keep on a bigger engine some day - I have a brand new mallory non vac advance dizzy but I'd be happy to sell it to get something more suitable with EFI etc? Forgive my ignorance, I am learning (slowly).
Alan
