Mk4 Golf brakes
https://forums.aussieveedubbers.com/threads/57716/mk4-golf-brakes
Put the Mk IV in for a sevice and they tell me the brakes are below the minimum thickness.
Pads are fine but duscs are gone :jesus
Only a 100,000 kms .......whatever...
Anyone know what ATE or DBA charge??
VW was quoting $518 front and $395 rear.
"Assuming" that is with pads.
Any other ideas on cost???
Barry
vwrallycar ·
100 000 kms is really good life. try going to somewhere like repco and buying DBA rotors and i have been using LUCAS pads. i find these pads really good.
try to avoid using a really cheap brake pad.
and you should probably look at changing wheel bearings as well, depending on whether they have been changed yet or not
jakjones ·
ring around you will do better
I bought the car at 50 odd thou. Brakes were still there - guessing they are the original.
So - pads - BRILLIANT!
Justsurprised then that the pads are going to last MORE than the discs 😂
Will ring - just being lazy and asking here on a Sunday evening
The rotors are about $130 4 a mark3 so i dont thing they would be much dearer for the Mk4
Ring South Yarra
I am just fitting a set to my sons car the VR6 there $100
vw54 wrote:Ring South Yarra
Thanks Dave
4 rotors
2 sets pads
$385 incl :bounce
vwrallycar wrote:and you should probably look at changing wheel bearings as well, depending on whether they have been changed yet or not
just spoke to anoth VW'er and Mk4's that stays on?
the rotor is only held on by one locking screw and it all just slides over.
I'm game for a $500 saving
yeah 2 bolts to undo n slide the caliper out of the way like most modern cars and hes right one screw to undo n the rotor comes off make sure yu uset he correct size screwdriver or you will burr the screw
