as the subject suggests, the right indicator wont flash. left works fine, is it just a flasher relay or do they both run off the same relay? any help will be greatful :beer
greedy53 ·
is it both rear and front and is it a 2 pin tube or 3 pin or 4 a little info goes a long way
but check both earths as if one is stuffed it will affect both and check both globes and all fuses
[ Edited on 22-10-2006 by greedy53 ]
pod ·
as steve says but will most likely be one of the globes👍
vwjon ·
do they all work with the hazard flashers? if so your indicator stalk is stuffed! if its just one side that wont work at all then it will bea fuse, if its just one light thats not working it will be the globe or earth, if none of them work its the relay!!
when you've finished checking let us all know what was the fixer! cheers jon
wozzie ·
it was only the front globe thats dead, replaced it this morning and its all good.
thanks for the pointers guys. have a good one 🙂
