76 kombi questions
https://forums.aussieveedubbers.com/threads/57739/76-kombi-questions
Baldy67 ·
A friend of my wife has got a 76 kombi camper,it has a 2lt fuel injected motor in it that is losing charge in the battery and when you start it,it is revving to around 3 to 4000revs and stays like that and seems to be running on 3 cylinders.......any help would be great
KruizinKombi ·
Firstly, if it is charging and then losing charge, either the battery needs replacing or there is something running when the ignition is switched off which drains the battery while the vehicle is parked. If in doubt, any auto electrician will be able to sort it out fairly easily.
As for the fast idle; Mine used to have a hose that came off regularly and caused a fast idle and poor running. Have a look around the engine bay and make sure everything is connected.
On the inlet manifolds on the in side is a vac hose that goes off to the brake booster.
bet this will be either cracked or loose
Baldy67 ·
i went and picked the kombi up on sunday,she had just charge it up and i drove it for about 45 mins home,stalled it going in my driveway and it only just started again.....by the way.....it is a new battery.....baldy
Baldy67 ·
i will have a look at the hoses........thanks guys
KruizinKombi ·
In that case, it sounds like it may not be charging, which could be the alternator, battery, or just dodgy connections. Start with cleaning the battery terminals, and check the earth strap too.
Again, an auto elec should be able to identify the problem within about 10 minutes....
Baldy67 ·
found a cracked hose,replaced it and it seems to run a lot better,when you hit the gas it revs up but still takes about 5 seconds to drop off again....getting a mate to look at that on saturday....cheers.....baldy
Baldy67 ·
replaced the rotor in the distributor as somebody had put in the wrong one..runs heaps better.just needs a tune up now .....cheers..vaughn (PS) the non vw mechanic that looked at it couldnt work out why it was running so bad,told the owner the motor was stuffed,had to be rebuilt........:jesus
[ Edited on 2-11-2006 by Baldy67 ]
KruizinKombi ·
Good to hear! :thumb
76camper ·
From factor kombi engines were fitted with a throttle return dampener to reduce emissions, not sure if FI had them tho. This might be the reason its taking a while to return to idle. If you dont want it ill have it ;-)
Baldy67 ·
its idleing fine now.is was the rotor that was wrong,timing was way out.....cheers.vaughn
kevo ·
f*****g back yard mechanics make our jobs a lot harder sometimes!!!
Baldy67 ·
i agree kevo.....:beer
