WTB: 38amp 12 volt genny
https://forums.aussieveedubbers.com/threads/57762/wtb-38amp-12-volt-genny
Anthiron ·
red light came on today.
looks like my gennys had it.
im in need of a 12 volt 38 amp genny, preferably with the plate to bolt to the fan shroud and the fan attached for a non dog house shroud.
oh and it needs to work too :P
sunshine coast
0439737762 dont ring me....U2U me
Nick
karmen ·
why not fit new brushes
5 mins work
also check regulator is not burned out (could be prob) auto sparky would tell in 2 mins check
does the light stay on with revs??
u can get a few more kms out of the brushes if u build the pressure (length )up with a paddlepopstick bit
if no go i may let u buy one
am down next week or Gympie soon
Anthiron ·
brushes have oodles of meat left on them. its gotta be something internal.
racq dude opend up the reg.
looked brand new inside.
he said it wasnt even pulling the contacts together as there wasnt enough current.
Volkswagenboy ·
Have you access to an armature growler? How much do you know about electrics, enough to disassemble it, run through a few continuity and resistance tests and short to ground/short circuit tests?
-Staggers.
Anthiron ·
i dont have the star tool to get the top off but im sure i could work something out.
ive got a day off work tomorrow to fiddle with it. i posted in tech talk asking what tests to do.
Anthiron ·
bump
karmen u have email
ragged ·
I have a reconditioned 12V 38 amp generater
Anthiron ·
thanks for the offer ragged but im really after a cheap 2nd hand one.
karmen ·
am thinking
wont take long to pull off
havent run it though
should do tomorrow
run, test, pull off ,and ??
how soon u want it ?
its on a 1500 sp tell me more re fan/shroud
mail me a pic of mtr
[ Edited on 24-10-06 by karmen ]
ancientbugger ·
Nick, give Wayne a call at Buderim he usually has a few around and he's reasonably cheap.
Anthiron ·
if its a stock single port engine it should be the right one.
i think the later dog house style fan shroud had a different fan.
if it doesnt have a dog house cooler it should be the right one bernie.
dont need it tomorrow but in the nxt few days i spose.
happy to pay postage as long as its a good un.
Anthiron ·
if its no good ill take barrys advice and give wayne a call at vw mechanical. i had forgotten about him.
karmen ·
ok try to do it tomorrow
post is cheap like maybe $15
Anthiron ·
how do u want for the actual genny bernie?
karmen ·
hows $80 exch so i can still test engines and have fan
will bring gear to change fan if needed
if i can get dwn early
Anthiron ·
hey bernie!
i fixed it!!!! hope u didnt pull the genny out for me already.
managed to get the pulley off and about an hour of fiddling around with it i managed to get the wire wedged under the terminal with a bit of solder.
karmen ·
ony man
i got my car trlr saftied today even had to go to weighbridge
now can pick up my 2nd sc ute wiff safaris wooppee
so no worries , happy for u
bit a crc shifts heaps of stuff
Anthiron ·
sweet.
ancientbugger ·
Good on you Nick, that should be everything fixed by now! It all seems to happen at once, after I got back from Kings Bore last weekend with the broken shockie bolt I hosed the buggy inside and out, drove it up a slope at my place to drain out at an angle of about 40 degrees, only meant to leave it for about ten minutes but forgot about it. The next morning it was dripping petrol out of the dipstick tube!!!! I now have what must be the cleanest engine ever. What should have been just a repair to the shock tower then became a complete oil change, new filter and everything taken off the engine and cleaned. The oil had the consistency of water!
Anthiron ·
i had that problem once.
could be your needle and seats?
i rebuilt my carby and it fixed, and another problem i had which i thought was the dissy ha ha.
i dont know how type 4 fuel pumps work but apparently on type 1's the pump can wear and fuel can leak into the sump that way too.
