My Ball joint rubber boots have been turning with the ball joint bolt [threaded part] so they are split...
Car has only done less than 1500kms since rebuild over past 9 years....
so Ball joints are virtually new....
but the boots are ripped open....
not perished etc...
Looks like i should have greased the small end of the boots so they would slide and NOT grab....
So the Large Side of the boot stayed stationary while the small side turned....
I have also had to replace my ball joint boots i got there from a local vw shop here in tas vw imports. But i'm pretty sure they were a repco universal ball joint boot.Seemed to fit ok Not as good as the german but they should do the job.
bajachris88 ·
Perhaps a professional or run of the mill steering or suspension place...
There should be plenty around to call into for 5 mins on ur way to work or whereeva, might have some luck.
VW shops didn't have the semi auto gear that i was after, but other places based on transmission/hyraulics had em. EVEN BLOODY AUTOBARN!... might work the same for u.
Drive it more!! And yes, some grease on the small shaft is good...
Maybe Repco for the boots? I'd like to know too...
vwjon ·
YES YES!! REPCO!! 2 boots for $6, the do carry them in stock as well, fitted some the other day!!
you bewdy!
Well thanks everyone..
I'll try REPCO....
better than buying a balljoint to get a boot off it....
