Hi,
I have seen some RHD wiring looms for sale....
they may have been made in Australia....?
When You see what a VW wiring loom costs....
its very expensive....
but I rewired My Beetle, using all larger than original wires.
a few Large cables to take feed power to the dash and fuses...
I soldered all utilux clips and used heatshrink on them...
made New battery cables...
I have seen the odd receipt for wire I bought from DSE in Sydney... and heatshrink... metres of the stuff, all sizes.. wow that stuff is expensive...
and ALL the Utilux attachments aren't cheap either when You are using Heaps of them...
so, its NOT impossible to rewire a beetle....
either Your way, or Volkswagenwerks way....
or even a mixture of both....
Best to pick a wiring diagram to Use...
the USA wiring diagrams are different to Australia cars...
The European 1969-70 is a good wiring diagram...
MOST IMPORTANT....
Write down everything You do...
and label all the wires... You can pull the labels off later if You want to... I wrote some wire colors down, and labelled some.. and the others are now called --
they do something - but not sure what..!!!!!:P:P
they are connected to something but not sure what --?:P
every now and then... I check unknown wires and label them using masking tape...
naturally, I have a few spare wires that start at the front of the car....
and finish in the engine bay.... SPARES - Just in Case..
Overall, i probably used twice as many wires than VW originally did... and all larger wires than VW used...
If the car has been stripped - totally - its not difficult to feed them thru everywhere.
It is time consuming....
Best of Luck
Lee 68AutoBug
