What type of grease do I use?
https://forums.aussieveedubbers.com/threads/58240/what-type-of-grease-do-i-use
Yogie ·
I have a 72 super beetle with IRS rear end. I will be fitting new rubbers in to where the swing arms attach to the pan and also for the torsion tubes. What type of grease/lubricant do I use to fit them and is there anything I need to be aware of when I fit them?
Yogie
No grease at all!
All you have to do is make sure the metal of the spring plates' tube section is clean and smooth
Yogie ·
Thanks VWCOOL. I thought they squeaked if you didn't lube them with something?
Yogie
Manual says to use powdered chalk....
on the outer surface to get it in easier....
nothing on the inner turning surface...
I would have thought rubber grease would have been OK
help stop the rubber wearing too...
cesiumfrog ·
thats assuming rubber bushes..
if you use nolathane type bushes you need to put plenty of grease otherwise they will squeak
i used moly grease on mine and no noise.
cesiumfrog wrote:thats assuming rubber bushes..
Did you have any problems installing the Nolathane bushes?
Yes, Moly is the BEST in grease.... Only one to use..
Lee -- 68AutoBug
cesiumfrog ·
no problems with the nolathane (or whatever they are)
other than first time i used them with the grease supplied and squeaked heaps...so bad i took them off and reinstalled with moly grease
if you mean ride..? possibly a little more shock transmitted...could be imaginary, but suspension seems to work better..i,m pretty sure thats not imaginary
Grease attracts dirt which wears the (unsealed) bushes. I have custom-made Noltec bushes in my car - no grease required.
phil ·
how does that work? no squeak?
i had thought of the dirt aspect and allway wipe any excess grease away to limit the accumulation...but
phil wrote:how does that work? no squeak?
yep, no squeak. No worries...
Yogie ·
I have rubber bushes for the rear but nylon? ones for the front end. So should I use Moly on the front and just dust the rears?
Yogie
Yogie wrote:I have rubber bushes for the rear but nylon? ones for the front end. So should I use Moly on the front and just dust the rears?
Yogie
Yep. The front ones aren't actually bushes, just grease seals
Yogie ·
OK. Thanks for the help guys.
Yogie
