Fuel lines
https://forums.aussieveedubbers.com/threads/58281/fuel-lines
mattie182 ·
How do I tell which fuel line is the inlet and which is the outlet, on the EJ22????:o
ElusiveStranger ·
If it's like an EJ20 the IN line runs to the right hand side of the block when viewed from the pulley end. It then goes to the left of the block and the pressure regulator is on the outlet pipe, just past what would be No 3 on a Volksie lump.
HTH
mattie182 ·
It has three lines all on the same side, (the right hand side)
One is 'breather' which runs through a canister, just not sure which one is which for the other two
mat
ElusiveStranger ·
Re-read what I typed 😉
The IN line first supplies the RHS of the block when viewed from the pulley end. Trace the RHS rail back to the 3 pipes, that's the inlet (pops outside in the cold, dark & rain) Inlet on mine is the uppermost of the 8mm pipes 🙂
[ Edited on 6-11-2006 by ElusiveStranger ]
mattie182 ·
ahhhhh Thanks
ElusiveStranger ·
Did you sort it & is it running yet?
mattie182 ·
sorted, not running..
Still got the wiring and the exhaust
ElusiveStranger ·
mattie182 wrote:sorted, not running..
Ahhh, the easy bits 😉
