hay troups i need an early dizzzy they are shorter in the body than a 009 i have one but its been altered and is now only good for parts the cap is short also making it ideal for ma rod it's been running on 2 cylenders from go i didn't pick it up until the drive belt broke driving the blower than i found the glitch
its the small one by bosch
[ Edited on 9-11-2006 by greedy53 ]
ctefeh ·
Greedy53,
I have a 40Hp vac only dissy I cannot use (has no cap, points ordinary). What numbers are on yours? I can compare them with mine and the oldvolkshome lists.
Regards
Ctefeh
Samblers ·
I've got two bosch vac only dissys - they will need cleaning up prior to use - contact me if you want to know the numbers
thanks friends knew someone would help
numbers
0231137091 i think this is the bosch
315905205B and vw
[ Edited on 10-11-2006 by greedy53 ]
ctefeh ·
Greedy53,
Mines a '65 40 Hp ZV/JU4R3. Yours matches to a '61-'64. Points and Cap are different part No's although you can swap dissy's to engines, so no go with mine.
Ctefeh
greedy53 ·
thanks for trying thats all i can ask for trying
greedy
