i have lost power to the ignition wire underneath the steering column. I broke into the wire here to run my accesories like oil pressure, water temp n other gauges, n thermo fans, and now nothing!
i used the multimeter and there is no current coming from this wire when the ignition is switched on.
BUT... i can still start the engine no worries.
i have cleaned the loom connecters under indicator stalk in the case it was a bad contact but still nothing.
any help or random ideas would be great.
if i cant go any further its off to auto sparky's so they can take a weeks worth of my hard earned student wages haha
cheers guys
[ Edited on 9/11/2006 by kevo ]
xornge666x ·
fuse??
that would be my first guess. This wire should come from the fuse box not direct from the ignition.
Double check all the fuses, if they are all ok, I would start tracing back up the wire to where it starts.
That is all they will do, and yes maybe for a few weeks of your wages!!
Are the fans running relays??
kevo ·
yer you close,
it was a build up of crap in the fuse slot causing a bad connection,
xornge666x ·
always start with the simple things!
Sulla ·
"the thigh-bone is connected to the knee-bone and the knee-bone is connected to the leg bone and the leg-bone is connected to the foot bone" Etc
