Hi has anyone fitted or knows of some photos of a porche 911 6cyl engine in a 1303 beetle. I would like to know how much room it takes up ie do you have to use the rear seat space
barls ·
from what ive read they dont fit in with out serious body work. ie the rear apron would have to be extended by about half a foot.
you would be better off fitting a 914 motor or a similar 4 cylinder ie kombi as they fit in the body with out serious modification
Whitty ·
Someone on here said a while back about Porsche motors - if they fit, they don't go; and if they go, they don't fit. :thumb
squizy ·
Reverse the gearbox over and mid mount it.
Do u just want a pic, or do u wish to investigate actually installing the engine?
Put a Subie in it. much better result for about half the $
bus914 ·
there is a black one that was converted by the porsche factory i think, it was mid mounted and the body was elongated between the door and the rear guard. i saw it in volksworld years ago, i think it was called the nordstat beetle or similar. i may try to find it later.
baybuscamperkid ·
listen to whitty, then listen to vwcool 😀😎
koolkarmakombi ·
'but my mate had one with a porsche engine in it..'
:vader
sorry
It is a rare conversion in my opinion. There are a lot of mods to be done. Not saying it cant be done but be prepared for a chassis up build.
Busses and type 3 have more room. Grey 57 has a 6 in his type 3 razor. There was a bus at dubs by the pub a few years ago, jamie olivers bus has one in it.
barls ·
just cause it has the porsche style fan doesnt make it a porsche motor. this is a common misconception
koolkarmakombi wrote:'but my mate had one with a porsche engine in it..'
:vader
sorry
Wasn't Jamie Oliver's splitty powered by an upright converted and slightly trick type 4 from a 914, not a 911 six? 🙂
:vader
sorry
ie: a Kombi engine...
Schmoburger ·
eeeeeeeeeeeexactly! 😂
Well... to be politically correct, the 914 engine's had sodium-filled valves as standard and the 2L 914 engine had wierd heads... so they aren't quite a Kombi engine 🤓
ANywho... I best stop trying to stir trouble! 😂👍
crewcabconnection ·
and we all go round again
Grey 57 ·
I thought Jamie Olivers Bus was a 2.7 six. 911 motor.
Schmoburger ·
You sure?.... I read that it was a bored, uprighted, porsche-fanned, very fancy 914 unit. 🙂
Oh well I may be worng but hey not important....the main thing is it still canes my bay! 🙁😂
