"Does the unit put an exessive drain on the battery?
No, the Generation 1 draws 40 amps @ max load (40,000RPM)"
Your pulling 40Amps through those pissy wires???
Not in my car ya wont!
You run one of these Greedy??
Any propper difference??
greedy53 ·
yes i am running a similar system and it only arms on full throtal than the torque is very evadent i run with murray from flat four in his twin cab and pulled away with ease up all hills now he's gonna fit one he was very impressed we tavel together for 4-5 years so any changes we notice
So are you pulling 40Amps through those pissy wires???
Look at the wire size of you head lamps and they are 1/3 the current
[ Edited on 17-11-2006 by Bizarre ]
I would think Your wires would be getting rather hot
running 40 amps thru them...
and the poor old alternator....
yikes,,,
OvalGlen ·
Steve, Ya Da Man....great stuff.
Have you seen that I'm running Hydrogen and
Oxygen into my Beetle now.
Extra Power ....from Water..!
Runs cooler. Less Petrol. and can run on "crap Unleaded"
as Good as if on $1.25 Premium...Nice and smooth.
Cheers.!
Have you finished the blower yet Glenn????
greedy53 ·
no i'm not running 40 amps through those pissy wires i wish some of you dorks would do ya home work you run 1 heavy wire direct to battery or alternator and a switched earth wire OF HEAVY DUTY TYPE
and it only works on full throtel not all the time shit i keep telling folks this and there is always some idiot who knows everything giving advice usually they are the ones sitting on a bar stool saying what they would do IF
[ Edited on 18-11-2006 by greedy53 ]
greedy53 wrote:wish some of you dorks would do ya home work
Listen dickhead - you post something up that has a link.
You look at the link and the is a picture of something that has pissy f&cking wires.
It says it pulls 40 amps.
What part of home work does your feeble brain not understand???
If you explain something people might have a chance of understanding
I give up - go post your links. Let no one ask questions.
greedy53 ·
FREQUENTLY ASKED QUESTIONS:
Will the Generation 1 supercharger fit my car?.
Yes.
Will it generate boost throughout the entire rev range?
The Generation 1 will generate boost in all applications up to 5ltrs.
Will I need to adjust the fueling on my engine?
No, your engines mass air flow sensor or manifold pressure sensor will adjust the fueling levels via the ECU
Do i need to purchase any aftermarket products for fitting?
No, The Generation 1 comes with a full fitting kit.
How difficult is it to install?
The Generation 1 takes approx 30 mins for instalation, full fitting instructions provided.
What does the product consist of?
25,000rpm motor, turbine, performance filter, steel shaft, full wiring, arm switch, size steppers.
Can the Generation 1 be used with a mechanical turbo?
Yes, The Generation 1 can be placed between the intercooler and the inlet manifold, this will generate boost in the lower rev range and eleviate mechanical turbo lag.
greedy53 wrote:and there is always some idiot who knows everything giving advice usually they are the ones sitting on a bar stool saying what they would do IF
Can only assume you are referring to me mate - but i look at this pic and was going by the info given to me.
If you keep on having problems talking to people i can only assume the problem is with the root cause
Good night :repuke
greedy53 ·
pictures are nice but the words tell the whole story
now sorry i'll be nice i had a shit of a day for nearly the same reason they idn't read the instructions only looked at the pictures
pod ·
lets just say it would work with a bit of extra stuff to make it safe, now no more mud slinging 🙂 and be happy little veedubbbers:party
barls ·
looking at the pic id say the wires would last a short time. they look pretty pissy, ie only about 4 gauge if that
Iwish4aSynchro ·
My 2 cents:
What difference is there to this unit. It also come with everything u need.
I think i mentioned this before and looked at the above mentioned supercharger in greedy's post. Think u have found a better one bloke???? 🙅
