Well i have been trying to get the details correct, and here is what i have come up with.
VW T3 stud 5x112
Ford wont fit 5x114.3.
Next it has become apparent that i can only use the 5x112 studded rims and all is good so how does anyone fit anything other than this?? Want some examples check out these.
http://www.brick-yard.co.uk/forum/forum_posts.asp?TID=1290&PN=1
Been ringin Wheel/rim mobs and you cant put anything other than the 5x112 on the car, apparently. If u go to a bigger rim offset it throws out the whole hub balance? If u redrill it makes the rim weaker i already knew this. If u add bigger nuts to fill the gap around studs(5x114.3) it can shear the studs away from hub under stress? Stuill got nowhere, lucky i havent bought the rims yet... Has anyone got any links or other info as to how i go about modifying other rims so as to make them fit onto my kombi?
Anyone got anything 馃お馃お馃お
[ Edited on 20-11-2006 by Iwish4aSynchro ]
Iwish4aSynchro 路
