F/S Rx7 Ser5 FC3C black GTX Jan90 build fact auto/Turbo/softop--WTD VW
https://forums.aussieveedubbers.com/threads/58738/fs-rx7-ser5-fc3c-black-gtx-jan90-build-fact-autoturbosoftop-wtd-vw
BASHOdi ·
I know that it is'nt likely that this will be of much interest to anyone here---but you never know -----
For sale: F/S Rx7 Ser 5 FC3C Black GTX Jan 1990 factory build turbo/ auto /softop only 58000klms
Item Condition: Very very good
Price and price conditions: $10990.00 ONO
Extra Info: VW beetle WTD will give good bucks allowance in a trade for right DUB
Pictures: Below more if you want em
Contact Details: PM for contact, post if you've got a question, it may save me from answering it twice.And others from posting(I'm just lazy)
Delivery & Conditions of Delivery:Pick up or buyer to pay & arrange shipping and insurance
This car is in as good a condition as you're likely to get anywhere, the motor rebuild was done at 54000K's an the car has 58043k's
I'm looking for a VW Beetle pref 74 on or an L or Superbug or a 76 but I'm not stuck on any as long as the condition is good and sound with no rust and it hasn't been modded by Mr ferkin stupid.
This car has been gone over from front to back and top to bottom. If it was bent, busted or faulty it has been fixed mostly using OE parts.
Engine
Totally rebuilt to Mazda specs with new just about everything – housings – plates – seals – etc etc etc. All new Mazda parts used. The rebuilt was done at 54,263klms by Tony Stacey at Mr Rotary ph (07) 3355 5669 if you want to check it out. There are no mods like "mild porting" or shortcuts in the rebuild whatsoever. The water pump was replaced with new at the same time.(cost $6300.00 all up--yup THAT rebuild)
Fuel Consumption
12.5-13.5klms – 100 city and 10-11 – 100klms highway.
Induction
Stock with K&N filter.
ECU
Stock. Don’t let Mazda tell you that they can’t read an import ECU, the codes are different, they’re not. How do I know? Mr Rotary has the stock (Aust) Mazda electronic tuning equipment and has no problem, the fault codes are exactly the same as Aust delivered. Neither has Ian Boettcher Mazda Ipwich.so if you want to have Mazda do all your servicing for you it’s just routine stuff for them.
Exhaust
OE dump pipe and cat replaced with 2½” stainless steel dump pipe and separate 3” metalcat. The OE temp sensor and air return pipe are plumbed back in per OE specs. Work done by Scotts Rods ph (07) 3812 0544. It goes into twin 2” Mazdaspeed mufflers. This is a great flowing system and gives a good sound while being street legal. The dump and rear pipes are completely heat wrapped.
Gear Box
Stock OE 4 speed auto. For those who call these boxes ‘slushers’ I suggest you think again. The box has three systems:-
D = 4 speed + overdrive
S = 3 speed very quick changing
+ an over-ride button on the gear stick which puts the box into 3rd gear from any other gear and holds it
If you know how to use one of these boxes good results are a given. Both fuel economy on one hand and performance on the other. The box has been fully serviced by Western Suburbs Automatics ph (07) 3277 1999.
Prop Shaft
Brand new fabricated by Driveline Services (the old one had frozen bearings through standing around too long). The shaft is also serviceable unlike the Mazda original.
Driveshafts
Fully serviced by Driveline Services , stripped , hotwashed , tolerance checked , re-packed and re-booted.
Driveline Services Archerfield- Ph No (07) 3275 7600
Diff
Renewed with second hand, checked and serviced (open 4.1) (original had funny knock which was probably caused by the frozen bearings in the prop shaft )… aaaarrrrggggh.
Brakes
Bendix Advantage pads, rotors machined, front wheel bearings re-packed, flexible brake lines renewed with Mazda OE, Bailey Brake & Clutch ph (07) 3282 3055.
Suspension
Slightly lowered (20m), Mazdaspeed springs F & R, Mazdaspeed front struts with KYB rears. This set up gives a good firm ride without driving your spine through the top of your skull if you go over a bump bigger than a flea turd and enough height to clear most speed bumps without leaving your cat behind. Back end sorted and recambered from jap stupid squatting frog to to sensibly good by J Thomas & son, Ipswich (07) 3281 4044.
Wheels/Tyres
Stock BBS 15x6.5JJ with Falken Ziex 205x60x15’s with heaps of tread. I’ll measure the tread depth if you’re picky but they’ve only got about 7,000 on them. I’ve found this combo works really well on this car and is a very economical as the tyres only run out to $110 a corner fitted and balanced. The wheels weigh 5.2 kilos and quite frankly to put say 17s on that will be in same type of weight range say 7 kilos is just far too expensive for me ($200 each in Japan, $500 each here) … you all know the story.
Interior
Stock, tan leather seats/door trim in excellent condition.
Exterior
Bonnet bare metal re-spray not because of damage, it had got tatty and had been Jap-patch sprayed so I had it re-done. The rest of the paint is original and in excellent all round condition. No rust anywhere in this entire vehicle.
Top
Tan fabric brand new fitted 3 weeks ago. Imported from the US (AA Best & Company). This top is stayfast fabric and about two shades more tan than it looks in the pics. The fabric is the same quality (Sonndecke) that is used by BMW/Merc. It was fitted by A Prestige Trimming Co ph (07) 3208 9389.
ICE
Still stock. I have made up a replacement plug and play cartridge to replace the OE unit (see pics). This comprises Autometer oil pressure, oil temperature and volts gauges and a Clarion DB 566 USB unit. This has not yet been fitted so if anybody is interested in buying the car we can talk about this then.
Summary
Heaps of additional remedial OE bits have been replaced … you know the stuff … little bits of plastic trim etc etc. Have receipts for everything but basically with the exception of the mild exhaust and suspension improvements this car is absolutely stock running beautifully as Mazda intended and used as a daily. Current mileage 58,043.
[ Edited on 13-12-2006 by BASHOdi ]
