2L Auto Starter
https://forums.aussieveedubbers.com/threads/58790/2l-auto-starter
RENNWAGEN ·
Can you bolt a 2 litre auto starter up to a 1600 flywheel. I'm currrently doing a suby engine conversion the standard starter was torqueing itself down and jamming so I was told to put an auto starter in. Now I'm having issues with that, it sounds as though the teeth aren't meshing properly. Did all starters have the same number/pitch on their teeth?
You may need a semi auto starter from a 1500 bug or Superbug. Im not sure if 2 litre starter would mesh properly. A semi auto starter can be use to directly replace the stock manual starter and they are slightly stronger than a manual starter.
Hi RENNWAGEN,
I have sent You some info via email...
Just remember I did this in 38C degree heat....
I hope it proves helpful...
Lee Noonan
