Aussieveedubbers 路 Watercooled VW's
T3 engine cuts out.
https://forums.aussieveedubbers.com/threads/59036/t3-engine-cuts-out
upset 路
My 85 T3, with rebuilt motor and new heads has an intermitent engine drop dead which the mechanic can't find. Hence my user name! Moving ignition wiring seems to do a temp fix but it soon stops again. Distributor to idle stabiliser wires show continuity. What can I do as it is Christmas close down!
Thanks in advance.
Bizarre 路
I had something similar
Would drive along and the car would die - but oil/gen lights would'nt come on.
Was the electronic ignition cutting out.
For $100 - 200 i would wack a 009 and points in and see if that fixes it
Oh.... 馃槀 welcome to the fun house 馃槀
greedy53 路
is it air or water if water my mate murrey hadthat the computer was cracked drove him nuts when the ute went around a corner if would flex the card in the puter
if water try another coil i had one great when cold a bugger when hot
upset 路
G'day Greedy53 and Bizzare, thanks for the tips. I have now found the gremlin, residing in the allegedly waterproof box on top of the coil containing two relays. Corroded contacts on these and an intermitent voltage path, noticed when I moved wires with motor running, I could hear a spark jump. Corrosion from blown water pump spraying coolant all over engine bay some years ago must have done that! Bug..r!
Engine now running sweetly, fingers crossed.
Bizarre 路
:thumb
greedy53 路
:bounce:bounce
