Shortened Sump
https://forums.aussieveedubbers.com/threads/59040/shortened-sump
MISS VDUB ·
Ok guys, it's Sump shortening time for me!
I was wondering if you could help me out with some pictures of the shortened sumps you guys have on your conversions?
Thanks in Advance!
Ash x
Direct from Custom off road
MISS VDUB ·
Thanks Pete, yeah i checked out the COR Sump on their site, but was curious to what other people have done themselves, and how it turned out?
Ash x
hellbugged ·
some here Ash....
http://forums.aussieveedubbers.com/viewtopic.php?tid=40369
pete wood ·
boof does a good one. my sump is actually still stock.
MISS VDUB ·
My sump sits quite close to the ground and definitely needs shortening.
Ash x
phatratpat ·
🙄 { thinks to self....do,es this motor make my sump look big ? }
DAM I gotta stop drinking !!!🙅
seagull ·
yes how is Matts going ? give us a look big fella
boof2332 ·
I'll get a photo of one I have...Paul popped in the other day and we just cut 25mm off the bottom of his and weldded a 3mm skid plate. We then welded the original drain plug back on. Thats what Paul wanted as it was quick, cheap and you still use about the same amount oil, just fills up a touch more....
The one I can make now uses one piece of steel to make the bottom and front side, I then bend the other 3 sides out of a piece of sheet and weld that in. The top plate is profile cut for perfect fit and welded on top. Its bigger than the first one we made..
Matt
