I have just removed all the roof lining and most of the carpet and side panels from "zoe". There is a very yukky underlay on the back doors ( I think its for the sound stuff) but underthat there is a sticky glue that is so hard to get off.
Does anyone know if there is something that will remove it so I can get the panel ready for painting or is it just something I have to keep working on with time it will come right?
Getting to the back set removal this weekend.
thanks for you help
Tania
mscabrio ·
I have not long done this on my 74 bug and I had to sit in the car with a paint scraper and scrape it all off .......
57oval ·
have you tried paint thinners
killakornkobb ·
prepsol
hus22l ·
Petrol!! It's been working great for me.
waltermitty ·
turps works a treat and is cheaper and safer. Mitchell
RODZ ·
I have tried all off the above for the same issue and someone had glued insulation to the roof with liquid nails. i ended up using goo off in a yellow tin from bunnings expensive at $18 bucks a tin but saved so much effort and got everything off.
good luck!!
Heintje Kuchen ·
White spirits is the trad stuff to use. a heat gun is also good but don't heat too much as spirits, prepsol or metho or turps or thinners could go up. let it soak a bit then wipe 'dry' then some little heats and it should come off pretty easy.
rebel ·
Yeah white spirits is the stuff to use ,its similar to turps without residue or smell
That's what they use on golf club grips
