how do you lower beetles?
https://forums.aussieveedubbers.com/threads/59417/how-do-you-lower-beetles
butidontunderstand ·
never having owned a beetle myself, i have a slight idea but i dont really know and just wanted a quick little explanation of how to lower early beetles..say a 61 beetle?
thanks,
karina :thumb
VWFOOL ·
u drive it down to wollongong and magic happens...
bajachris88 ·
Get a fat man to drive it for ya :kiss!
warb ·
sams not that fat....
Schmoburger ·
do some bushbashing CHris-style... fracture the torsion bars... bend the trailing arms... looks just as saggy as a professional job at a fraction of the cost! 👍
Unfortunately tho it hasnt worked on my Kombi! :cry:
[ Edited on 8-1-2007 by Schmoburger ]
bajachris88 ·
lend me ur kombi for a week schmo... i'm sure i could arrange some suspension lowering...
mahahwhwhwhwa
oval TOFU ·
ask rupewrecht.. he knows!
[ Edited on 8-1-07 by oval TOFU ]
bond ·
karina - you can get weld in adjusters into your front beam - should be k/l beam - will lower the front ~2.5inch. - also dropped spindles will lower the front a further 2.5inch.
the rear is a little more difficult to do and explain - there are no doubt tech articles and how to's in the tech forum - otherwise if you're not doing it yourself, speak with the guys at your local vw mod shop - get yourself a quote etc.
goodluck
nick
[ Edited on 8-1-2007 by bond ]
whatnow ·
you have two decient options (or you can use a combination of the two)
the most common being having adjusters welded into the front beam, there are two different styles, both have thier good and bad points when it comes to fitting. either way you need to have the welding done by someone who is GOOD with a welder. as far as i know in NSW you (for legality's sake) need to have the modification engineered, though i expect that 90 percent in NSW aren't. the ride will probably end up harsher and if you want a serious drop you will need shorter shocks or extended shock towers.
the other way is to fit dropped spindles. these are front spindles that are fitted in place of the stock spindles and have the stub axle mounted higher (generaly 2 1/2 inches) than stock = 2 1/2" lower front of the car. you can get both welded and new cast spindles, either way they will have to be engineered though from what i know your chance of getting welded spindles passed is very very very small. the best things about dropped spindles is the ride quality stays virtualy stock and you don't need to cut up the front end (a better option if you are modding a clean original car) plus there is no need for special shocks etc. most dropped spindles do widen the front track, which goes against the current trend of narrowing the front end.
or you can combine the two to get decient ride with adjustibility... or with some other mods, very low.
if you are only lowering the front (or lowering the front more than the back) this will interfere with the front caster, to this needs attending to by adding caster shims between the front beam and it's mount point.
if you want to go realy low there are other things that need doing but someone else can explain them.
there have been other methods used in the past but from what i have been told they don't rate when compared to those above.
edit... ok that took longer to write than i thought.
[ Edited on 8-1-2007 by whatnow ]
amazeer ·
pull their legs off.
or you could get a type 3, much easier to drop.
thanks for that guys 🙂
they do seem to be alot harder than type 3s to lower...oh well these things happen :P
oval TOFU ·
I should stop posting useless posts... ^^^
Check out my thread... u2u me if you want to ask any questions - I'll be only too happy to help!
http://forums.aussieveedubbers.com/viewtopic.php?tid=19010&page=3
PS: lowering the rear is easier
[ Edited on 9-1-07 by oval TOFU ]
thanks :bounce
*did* ·
lowering the rear on a beetle is pretty much the same is lowering the rear on a type 3, however, lowering the front is quite different.
Hertz ·
oval TOFU wrote:ask rupewrecht.. he knows!
Cool, when is he planning to lower it. LoL
VWFOOL ·
haha u made my day man
oval TOFU ·
Hertz ·
Needs to go down about 1.5 to 2 inches more. Huge improvement though. Dan you should terminate those 165s on the front, do they rub at all?
VWFOOL ·
are you game?
Hertz ·
Thats the shit.
oval TOFU ·
Dan, you listening?
jason1957 ·
Go 135s on the front for sure!!! Great looking ride, well done👍
BUGBOY ·
This sled will take 145's up front with no problem and also stop the headlights from smoking. LOL
Smoking is harmful to your body Dan:P
