I needs help - Brakes shuddering when goin\' forward :(
https://forums.aussieveedubbers.com/threads/59497/i-needs-help-brakes-shuddering-when-goin-forward
bajachris88 ·
Hi guys. i just did my first valve adjustment 2 days ago... best thing i eva done to the thing, cause that engine and transmission purr so nicely now. LUV IT!
But... the brakes... i do know i need to do an adjustment to em... and check whether i need new shoes/pads. But just out of curiosity, i got a big clunking problem...
I would be chugging along in my bug and when i then depress on the pedals of the brake i hear this big clunk. They still work, but makes a hell of a noise. and only when braking in a forward direction and not a reverse :o
We had this trouble to my mother's 97' ford laser, turned out being some shims that were misplaced from the brake fellas, dunno if it would be the same go here... i wouldn't have a clue.
any help would be sweet guys... i do know my drums are in need of a major adjustment... could it be that? too mcuh free play making them move around and clunking/thumping with pressure?
BTW, i got front disk brakes and rear drums... 1969 semi auto.
best regards,
christopher.
Volkswagenboy ·
Where's the clunking coming from?
-Staggers.
Volkswagenboy ·
I.E: Front/rear/steering?
-Staggers.
bushed ·
i'd first check the calipers are on tight
ie there are 2 bolts on the inside (wheel can be left on)
they may be loose (do bth sides)
while at it check wheel bolts if tight
Matt Ryan ·
Chris, - maybe it's the nut behind the steering wheel?
LOL,
Matt.
Schmoburger ·
Volkswagenboy ·
How to fix the shuddering in the brakes:
1. Get a gas axe.
2. Cut your brake pedal off.
3. Drive really fast.
-Staggers.
sinecure ·
Shims or maybe a pad separated from the backing?
Disc calipers loose (nod to bushed) or bearings worn/poorly adjusted?
Or maybe just shiny discs and pads. May just need a machine.
