Having just taken possession of our dual cab kombi...
I'd love to see some ideas of what wheels people have put on their bay window kombis. If necessary, tell us what adaptations you did to put the wheels on.
馃檪
VWMA Editor 路
Second hand Audi 15" alloys. Bolt straight on. Good clearance from wheel arches to allow the Kombi to be lowered, especially at the rear. Slight reduction in turning circle - steering stops had to be wound out a couple of turns to prevent tyres rubbing on standard full lock.
$100 each. Centre caps from local tyre store (front caps had the locating tabs ground a touch to fit the tight gap between wheel centre and grease cap). Wheel studs off a Landcruiser.
VWMA Editor 路
How they look (Double Cab has been lowered a little more since photo taken)
Spellbound 路
They look shweet! :thumb
vwtyp2 路
MWS narrow 5 BRM replicas.
bolt straight on.
vwtyp2 路
same bus with ROH adrenaline 17x7" rims.
also bolt straight on from a Mercedes.
$2.63 homebrand baja 路
tyre black...she looks wikked moite 馃槀
helbus 路
You've seen our bus yeah?
helbus 路
They are aftermarket Mercedes Alloys as fitted by Canterbury Rd tyres in Bayswater. I will say I was not impressed with the service, the wheels look nice.
warb 路
mirc steelies on a split... bay studs tho.. does that count?..
modulus 路
Special 14" X 5.5" steel wheels, especially modified to fit the Bay Window Kombi... Adaption comprises lining up the studs with the holes...
topless bug u have GOT TO LOWER THAT as soon as possible man! looks too crazy hey
Joel 路
i think that trolley jack under it may be adding to the whole illusion :P
toplessbug 路
yea its heaps lower than that ,sorry i posted the wrong pic see if i can find another..I cant go too low as i go away every 2nd weekend fishing with my boat on the back over some bad dirt roads ..
kombi_kid 路
mercedes aftermarket wheels 17x7 had to get centres widened
Hertz 路
You can get repro Gas Burners in 5x112 pcd now. Bout the same price as a good set of repro brms. I think www2.cip1.com have them.
amazeer 路
hmm you show me yours and I'll show you mine.馃槉
Jay_1965vw 路
Anyone else? 馃榾
PHAT BUG 路
These are some 17x7.5 rims that I have been machining to suit kombi, there $300 set of 4.
Jay_1965vw 路
So is 5 x 112 PCD the correct fitting for a kombi? I'm getting conflicting info about what is exactly right, and what 'just about' fits...
Plus the tyre people don't seem to have a CLUE about stuff this old.
Thanks again 馃檪
helbus 路
5 x 112 PCD is correct. Mercedes and Audi use this pattern also
vwtyp2 路
the other thing to consider is centre bore diameter.
I have Passat 17" rims on my T3 which are 5x112pcd but had to machine out about 2mm from the centre bore of the rims to get them to fit.
helbus 路
Also to consider is whether the wheel studs are long enough for the wheels you wish to fit, understanding that the original studs were designed for a pressed steel wheel centre.
You can get longer studs.
Also the angle of the nut face can be different on some wheels.
bus914 路
baybuscamperkid 路
yay! jay's got a bay 馃榾
Jay_1965vw 路
Yup! Jay surely has - well - Mal has, which equates to pretty much the same thing. (note - don't go for VW bloke - go for Non-VW bloke and turn him to the dark side!!)
Looks like we'll be getting some 18" chromies... they look pretty hot!
greedy53 路
my 86 t3 and 71 bay
Jay_1965vw 路
They both look awesome greedy! What size are the ones on the bay?
greedy53 路
17x7 off a toyotaand 14 on the t3 early ford
Schmoburger 路
They off a T-bird Steve or even before that era!??!... whatever they are I love em!... didja have to modify them or the hubs at all to get em to fit? 馃槑
And in keeping with the flavour of the thread and to cover up my hijacking... here's BC's wheels... nice simple black stockers with chrome caps, cheap $5 AutOBarn chrom dressrims, and very dodgily applied 'walls. 馃憤馃槀
Floats my boat... 馃檪
ColumBUS 路
i have a set of the same rims as phat bugs sitting in my garage, they hacve tires and everything, but im waiting until its lowered before i fit them. also gives time for the tires to cure exxxtra hard!
Schmoburger 路
SO that's what's going on the Pube... awsome! 馃槑
馃お I feel all strange but I honestly really really luv stock wheels on kombis, beetles etc.... they are so...um Vee-dub, I am sorry, but don't see any ricers etc slammin on sum chromed dub rims.... I don't care if I am cast out to the wilahness.. I think they are funky in thier own right, so bulbous, round n shiney they just shout "VEE DUB".. mmm yum :thumb (sorry jay, ur a sweetie don't mean harm, nor flamin, just voicing my opinyun!) :bounce plus surplus hubs have multiple uses and the origins are instantly recognisable 馃憤
Schmoburger 路
Word brother Heather! 馃榿
how fun is it playing "Spot the VW trailer"!?!? 馃槀馃憤
Jay_1965vw 路
Hey Heather - as if I'm gonne be offended! Wolfie has his stockies on, just Mal is going for a different look with the kombi 馃檪
