ECU\'s & Harness\' for sale in WA
https://forums.aussieveedubbers.com/threads/59523/ecus-harness-for-sale-in-wa
humpty ·
Ok gang.... Things have changed in my shed of late and its looking like the EJ25 Notch is to get a Sti upgrade and the low buck EFI 1776 is not gonna happen.... the 2276 is gonna get all the love, so don't you worry about it ok!
So... I have two ECU's & Harness' for sale.
Descriptions are as follows...
Please note that these systems are secondhand and prices include postage anywhere in Australia.
1x OEM Subaru ECU, relays and complete uncut harness for a quad cam EJ25: Price $450
1 x WOLF 2D ECU and complete harness to suit any NA or turbo application. Harness can be used on 4, 6, or 8 cylinder engines. It can run any electronic distributor drive ignition systems. The ECU was checked/serviced by the WOLF distributor with receipt, and it also comes with the manual: Price $400
I can be contacted via U2U or Email as Im here most days....
Cheers....
andrewmurphy ·
Am i right that the wolf 2D only does fuel? also does it come with any sensors?
humpty ·
Yes it runs fuel, and it does have ignition too, but it doesn't have sensors.... It is designed to run using most generic engine sensors (such as GM) that are found on common cars.... Obviously VW's don't have many of them, so you will need to add them. What is in this kit is the complete harness with connections and ECU/Controller, and the manual. Google it if you need more information....
[ Edited on 26-2-2007 by humpty ]
humpty ·
humpty ·
Strike me pink!.... stuff moves quick here!!!!
humpty ·
Back again!
have any throttle bodies???
humpty ·
Falcon or Subaru?... Don't see the point of dual 'weber' style TB's.... Just more shit to get in the way...
seagull ·
the wolf is like Kurts set up Simon , he has a type 4 if I recall with a eaton M90 super charger fitted .
this has the hand control unit for setting fuel & the in board turbo timer as well if I recall these units .
Dam that is a low cost way to make a fuel injection / turbo vw come together
The harness has the female injector plugs on it mate ?
humpty ·
seagull wrote:the wolf is like Kurts set up Simon , he has a type 4 if I recall with a eaton M90 super charger fitted .
Yeah Kurts is the 3D Ver4 model and it runs sweet on his car.... And the injector plugs are the female type....
seagull ·
Paul came over & he is keen on this in his 2 some thing bild
I hope he does it as it will be cool driving the 23 window back from tassy to perth at the end of the year
were going to slam it as well , just for the trip :thumb
humpty ·
Yep... My straight axle kit and and prolly some of RobK's spindles too... Will wack some adjusters in when he gets it back here..... Cool huh?
