From 1.6 litre to 14 litre, should I do it?? :D:D
https://forums.aussieveedubbers.com/threads/59542/from-16-litre-to-14-litre-should-i-do-it-dd
Volkswagenboy 路
Do ya think it'll fit in my bug???
That's 14 litres, 530 horsepower, turbocharged, direct injection V8...
I doubt it!
-Staggers.
barls 路
id like to see the face of the engineer when you told him what you wanted to do 馃檪馃檪馃檪馃檪
Volkswagenboy 路
lol
You know, I should actually ask an engineer just for a laugh!
-Staggers.
pod 路
watch out The Munsters 馃槀 as you would have to build a platform just to sit on and steer out the back馃憤
[ Edited on 13-1-07 by pod ]
Joel 路
hey it worked in herbie
a bus engine was the only way they could get it to do those huge wheelies
whatnow 路
sorry but i think that that V8 is the wimps option.....
RR Griffon mk58 36.7l 2435hp is more like it. 馃檪
[ Edited on 13-1-2007 by whatnow ]
pete wood 路
Volkswagenboy wrote:Do ya think it'll fit in my bug???
I doubt it!
-Staggers.
I'd love to build a big hotrod with a motor like that. would be the ultimate family cruiser and you could tow a caravan in style. 馃憤
Volkswagenboy 路
I doubt it!
-Staggers.
Or a 65 tonne B-Double!
-Staggers.
Schmoburger 路
Pansies.... this'd eat a Griffon for brekkie.. and its aircooled too hehehe
The Wright R-3350-32W Turbo Compund Duplex-Cyclone... 18 cylinders, 33.5 litres and 3700HP of direct-injected turbo-supercharged fun! :bounce :jesus
They'll drop right into a bay! 馃 馃槀
[ Edited on 13-1-2007 by Schmoburger ]
whatnow 路
schmo, i had discounted radials as too big for a beetle but hadn't considered a bus....
i like the way you think.
would you mount the scoop on the roof or fabricate a second and mount one on each side?
i'm having visions a display bus with a 23 window roof (well the sunroof and first 3 side windows), RAAF cab roof windows, poss angle choped as per the hotwheel drag bus with cooling flaps cut in a ring around the body. "cyclone in a bottle"?
any chance one of you photoshop people could mod the roof on this for me?
[ Edited on 14-1-2007 by whatnow ]
Schmoburger 路
whatnow wrote:schmo, i had discounted radials as too big for a beetle but hadn't considered a bus....
This is indeed sounding very tempting... would be a great idea for a display bus, however even cooler would be a double-door bay panelvan... the ultimate sleeper!... would look almost totally stock until such time as you open the slider's to allow for cooling 馃榿
Now hey... why didn't anybody ever think of sliding cowl-flaps before??... would have solved the B-29's overheating (ie catching fire and blowing up off the end of Anderson AFB 馃槀) issues in a snap... 馃お
OOOOOOOOOOOOOOOR we could go about it a totally different insano way... and graft the engine nacelle of a DC-7 or P2V into the back of the bus, raise it a few splines, and fit a shortened 4-blade Hamilton-Standard constant-speed bugmasher onto it... not only does it look nuts, it will also do away with the need for a solid titanium clutch, flywheel and transmission! 馃 :bounce
[ Edited on 14-1-2007 by Schmoburger ]
whatnow 路
Schmoburger wrote:it will also do away with the need for a solid titanium clutch, flywheel and transmission!
you could always mount the cyclone east west and run it with a chain drive to a solid axle, as for a clutch... who needs one, just a line lock and water sprays for the rear tires so you could hold it at the traffic lights.
well its a thought.
i think if you had worked at boeing (is that how you spell it) in the 40's the war would have been over months earlier.
while we are modding with vw concepts, imagine the reduction in combat fatigue in bomber command if all the heavies had been fitted with golde ragtops so the crew could kick back and relax on the way home from a hairy raid. (adding one on the bottem would have made bailing out easier too)
sinecure 路
Bung it in your Rangey, Brenton!
BTW, love your new avatar pic 馃槈
